New 62-1, what to expect?
Old Mar 31, 2005 | 11:50 AM
DelSlow's Avatar
Hot Dicken's Cider
Well, I just got my new Turbonetics 62-1 and almost everything else I need to get it running again. I know there are a million threads like this, but what can I expect HP and spool-wise? Its a conventinal bearing turbo, .96 turbine housing, P trim wheel. Most likely getting the turbine housing jet hot 2000 coated and the compressor housing extrude honed. Im going to be running 16-17 psi with water injection. Mods are in sig, plus several others that are coming like the MazdaRacing comp pulley system, some kind of ignition upgrade, cooling mist kit, and several others. Streetport is a "stage 2" from rx7store, with RA seals.
Old Mar 31, 2005 | 12:36 PM
RacerXtreme7's Avatar
NASA geek
Purty!
Expect 10 psi around 3500~4300rpm and putting down 380~430 whp @ 1 bar (14.7 psi) (sorry for the large range but its dependant on porting and tune amoungst MANY other variables).
FWIW, you'll see much more gains extruding your turbine housing then your comp housing.
~Mike...................
Old Mar 31, 2005 | 12:42 PM
weaklink's Avatar
Resident Retard
https://www.rx7club.com/time-slips-dyno-128/my-12-second-run-%2Avid%2A-409737/
Old Apr 1, 2005 | 08:09 AM
diabolical1's Avatar
looking really good ...
you said you'd be running 16 to 17 PSI. how much does it blow when maxed out?
LongDuck
Oct 7, 2015 08:12 PM
Snook
Oct 4, 2015 08:47 PM
apooch
Sep 4, 2015 10:27 AM
