I Need A Wiring Harness To Go From Auto To Manual!!!
Old Mar 25, 2005 | 04:14 PM
vizion47's Avatar
Exclamation I Need A Wiring Harness To Go From Auto To Manual!!!
Will Buy The Wiring Harness From Anyone Who Has It
Old Mar 25, 2005 | 04:20 PM
Siraniko's Avatar
RX for fun
Why?? if ur switching from auto to stick, just change the tranny/pedals
Old Mar 25, 2005 | 04:25 PM
vizion47's Avatar
Robert Said I Needed A Diff Harness
Old Mar 25, 2005 | 04:28 PM
Siraniko's Avatar
RX for fun
if you need it, drive up to LA (san fernando valley) junkyards and grab it.
Old Mar 25, 2005 | 05:04 PM
darkfrost's Avatar
Its not ABSOLUTELY necessary. You can do the swap without it, but will have to rig up something for the reverse lights. Other than that, its not necessary.
Old Mar 25, 2005 | 05:17 PM
680RWHP12A's Avatar
rig something up?? i dont like the sound of that!! what about the neutral saftey switch?
Old Mar 25, 2005 | 05:18 PM
Siraniko's Avatar
RX for fun
just be sure that the tranny comes with those wires for reverse lights. it will be a direct plug in to the stock harness.
Last edited by Siraniko; Mar 25, 2005 at 05:26 PM. Reason: I just remember something
Old Mar 25, 2005 | 05:57 PM
vizion47's Avatar
got one! ode' to the rotaryshack team!
Old Mar 25, 2005 | 10:00 PM
Moonchopper's Avatar
errr... I never knew that manual trannies had wiring harnesses. I didn't know they had anything electrical with them. Is there supposed to be a neutral saftey switch? If so, then mine definately doesn't have one that works properly. I've accidently tried starting the car in reverse 2 or 3 times >.< (First months that I had the car [had never driven a stick on a daily basis before]. I don't do it anymore, though )
Old Mar 25, 2005 | 10:01 PM
680RWHP12A's Avatar
your harness has been rigged!! uuuaaahhhh
Old Mar 26, 2005 | 11:48 AM
darkfrost's Avatar
Mine's soon to be rigged
Nothing connected to the tranny yet, finished the auto-5spd swap not too long ago.
Old Mar 26, 2005 | 07:27 PM
peejay's Avatar
Old [Sch|F]ool
The what?
All of my RX-7s have been able to be started in gear. It's almost a required function for *when* your clutch hydraulics die.
The wiring harnesses are identical in many respects, after all manual cars have the PRNDL-light connectors under the shift boot (aka the connectors people like to connect and blow the interior lighting fuse). The neutral switch and 5th gear switch are mainly emissions concerns, although the emissions testing performed in most states never goes up into 5th gear and so it's not that important anyway.
- Pete (my car's backup lights don't work, either...)
Old Mar 27, 2005 | 04:56 PM
ebrown0104's Avatar
i was wondering about the pedals... i am looking at an 85 GSL, and the only downside to the car is that it's an automatic. how hard is it to swap the pedals in? do i have to weld any brackets to the firewall, or is it all bolt-in? thanks for the help, Ian
Old Mar 27, 2005 | 05:58 PM
darkfrost's Avatar
Its all bolt in, but is a total bitch since you have no working room. Its a good idea to try and get pedals from the same model year, and is much easier to keep the original bracket and change the actual pedals than to try and replace the entire bracket with the pedals. I learnt from experience, rx7doctor set me straight.
Old Mar 27, 2005 | 06:10 PM
ebrown0104's Avatar
cool, thanks for the info. anything else i should know about a tranny swap, besides unbolting the old one and bolting the new one in (along with wiring up reverse lights)?
Old Mar 28, 2005 | 11:57 AM
darkfrost's Avatar
What year is the automatic? If its got the overdrive (like mine did) You will have to make brackets for the crossmember to bolt the tranny up.
Old Mar 28, 2005 | 11:17 PM
vizion47's Avatar
auto driveshaft is different from manual.....you need a little center console thing for manual, you need clutch flywheel and pressure plate, you need the clutch master cylinder and the lines...the pedal assembly and the wiring harness, and then you have to change your timing to manual...throughout bearing, the fork for the clutch
Old Mar 28, 2005 | 11:22 PM
ebrown0104's Avatar
thanks again, but i don't understand what you mean by changing the timing. if you could clarify
Old Mar 29, 2005 | 01:36 AM
vizion47's Avatar
im pretty sure that it is slightly different for manual so you get a timing light and adjust it, the timing is the ignition, and the exact setting is in the manual
Old Mar 29, 2005 | 03:48 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
The neutral safety switch is on the automatic tranny equipped cars and keeps the engine from starting unless the AUTO tranny is in neutral. You just have to jumper the switch, you don't need a different harness. Don't make things harder than they have to be.
Professorpeanutrx7
Aug 15, 2015 01:38 PM
