thinking about slick lights
Old Mar 22, 2005 | 09:00 PM
renagade_rotary's Avatar
Not a Racist
building my own
state your opinion and what lights i should use for the different beams any input is apreciated
Old Mar 22, 2005 | 09:09 PM
smnc's Avatar
EliteHardcoreCannuckSquad
You mean a flush-mount kit? Get rid of the pop-ups?
CP Racing sells a set-up...
www.cpracing.ca
Old Mar 22, 2005 | 09:29 PM
Not a Racist
id rather do it myself though lik everything hand made by me
but i wanna know which lights i should use
Old Mar 22, 2005 | 09:44 PM
rxseven07's Avatar
Registered pimp
****** s2000 lights, or 350z lights, good luck on buying them... im talkin about the projectors, not the whole assembly
Old Mar 22, 2005 | 09:51 PM
smnc's Avatar
I was planning a mod with Hella aftermarkets once... I was going to use a foglight for low-beams, and a driving light for the highs...
Old Mar 22, 2005 | 10:22 PM
jes's Avatar
jes
Rotorhead
Exclamation use headlights
Why not just use the headlight modules? Low beam headlights have an upsweep on the right, fog ilghts are flat. You will think you're going blind if you use fog lights for low beams. If you find the right dealer, they will sell you the ECE versions, a big improvement over SAE... They come in Halogen & Xenon (big bucks!)
90mm Headlamp Module
Old Mar 22, 2005 | 11:01 PM
you can buy nssan and porsche projectors on e-bay...but they are most likely stolen, so be ware
Old Mar 22, 2005 | 11:45 PM
steve84GS TII's Avatar
FB+FC=F-ME
Those are the modules I used.Theyre DOT legal and reasonably bright if you keep your covers clean..You can get them here....
http://www.rallylights.com/
Old Mar 23, 2005 | 02:44 PM
Not a Racist
these are the ones i like
http://www.rallylights.com/hella/90mm_modules.asp
Old Mar 23, 2005 | 08:14 PM
FB+FC=F-ME
Yep,same ones.
The only down side is that those modules are pretty big.I had to run them on the inside and as far down as possible just to get them to clear my lids.Also,they use an H-9 bulb which is kinda odd.They came with 65W OSRAM bulbs which are very good quality,but plain clear.I wanted to find some "white" bulbs to remove some of the yellowish look to the lights.The only ones I found in H-9 were XD5's with some Japanese writing on the label...you know the ones!.They were 65W and were nice and white with barely a touch of blue.But the blue color of the glass cut down the overall lumens so much I was scared to drive at night.If you do go with an H-9 module,stick to the stock clear bulbs.
Old Mar 23, 2005 | 08:22 PM
rxseven07's Avatar
Registered pimp
^ do those have the clean blueish lighs like the s2000 and 350z? or are they just standard yeller?
Old Mar 23, 2005 | 08:32 PM
FB+FC=F-ME
Read my post above the picture!........:;-)
Old Mar 24, 2005 | 05:14 PM
smnc's Avatar
Damn! VERY SWEET!
The ECE's are legal here in Canada too...
Hmm... maybe...
Old Mar 24, 2005 | 05:25 PM
smnc's Avatar
I won't start ranting about blue light again...
I'm just going to post a link...
http://www.danielsternlighting.com/t...e/bad/bad.html
http://www.danielsternlighting.com/t...good/good.html
Old Mar 24, 2005 | 09:09 PM
FB+FC=F-ME
That blue light post was VERY imformative and indefinately proven to me,when I swapped the stock clear bulbs back into my modules.All the difference in the world.
Old Mar 24, 2005 | 09:36 PM
smnc's Avatar
THANK YOU!
I only ask that you spread the word of Dan, every time someone starts yammering on about their new "ultra-white" blue lights...
David Hayes
13
Sep 5, 2022 12:45 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
RCCAZ 1
Aug 11, 2015 07:05 PM
