Where do you get factory 20b tension bolt seals?
Old Mar 14, 2005 | 08:46 PM
GtoRx7's Avatar
Collections Hold
I have everything to rebuild my 3-rotor, but where can I get the tension bolt seals, for the larger tension bolts? I have plenty for the 13b size bolts, but my 20b has two or three front and rear that are way larger than the 13b ones. It s a series C motor. If anyone knows where I can get this, or a mazda part number, let me know. I also need the intake gasket, but I found those on ebay. Thanks
Old Mar 14, 2005 | 10:46 PM
GT1-20b's Avatar
Mazda Motorsports.
Old Mar 15, 2005 | 04:50 PM
IronMdnX's Avatar
Glutton for Punishment
Mazdatrix also has them
Old Mar 15, 2005 | 09:10 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
I didnt see any of the larger 20b tension bolt seals on mazdatrix's website. is this something they can get, and just don't list?
Old Mar 17, 2005 | 04:31 PM
IronMdnX's Avatar
http://www.mazdatrix.com/cartinput.htm
Part # 10-E55A-NF01
Old Mar 18, 2005 | 08:36 AM
Merovingeon
Veteran: Air Force
Awesome iron. so they do have 20b parts, they just dont list them on their website. you have to know the part numbr and go that way
Old Mar 18, 2005 | 10:10 AM
IronMdnX's Avatar
It's all in their full price list...
10-2710-8DJ1.....3R GASKET SET.........GASKET SET 20B........$ 602.21
10-E050-NF01.....3R BEARING MAIN.......FRONT OR REAR..........$ 45.42
10-E420-NF01.....3R BEARING MAIN.......CENTER.................$ 50.14
10-S600-NF01.....3R O-RING SET 20B.....O-RINGS ONLY 20B......$ 269.91
10-E55A-NF01.....3R TENSION BOLT SEAL..FOR LARGE BOLTS........ $ 3.60
3R-CWF...........3R COUNTERWEIGHT......FRONT..................$ 78.08
3R-CWR...........3R COUNTERWEIGHT......REAR...................$ 78.08
3R-DOWL..........3R DOWL PIN...........F HOUSING (NEED 2)..... $ 8.26
3R-ECC...........3R ECCENTRIC SHAFT....NO LONGER AVAILABLE...... 0.00
3R-ECC-NUT.......3R ECCENTRIC NUT......FRONT ECC NUT..........$ 16.73
3R-G1............3R GEAR STATIONARY....GEAR FRONT............$ 176.18
3R-G2............3R GEAR STATIONARY....GEAR CENTER...........$ 136.57
3R-G3............3R GEAR STATIONARY....GEAR REAR.............$ 228.59
3R-GSK-INT1......3R GASKET INTAKE......MANIFOLD TO ENG........$ 16.50
3R-GSK-INT2......3R GASKET INTAKE......BETWEEN MANIFOLDS......$ 10.60
3R-GSK-PAN.......3R GASKET OIL PAN.....PAN GASKET.............$ 23.46
3R-H1............3R HOUSING #1.........HOUSING FRONT.........$ 400.75
3R-H2............3R HOUSING #2.........HOUSING SECOND........$ 622.85
3R-H3............3R HOUSING #3.........HOUSING THIRD.........$ 418.16
3R-H4............3R HOUSING #4.........HOUSING REAR..........$ 372.87
3R-MAN1..........3R MANIFOLD UPPER.....UPPER PLENUM..........$ 252.75
3R-MAN2..........3R MANIFOLD LOWER.....LOWER HALF............$ 269.91
3R-PAN...........3R PAN OIL............OIL PAN...............$ 147.43
3R-PAN-PU........3R PAN OIL P/U........PICK-UP TUBE...........$ 42.93
3R-ROTORLC.......3R ROTOR KIT CARBON...2MM CARBON............$1312.00
3R-TB10-1RL......3R BOLT TENSION 10MM..#4/#1 LOW LEFT CORNR...$ 26.17
3R-TB10-5F.......3R BOLT TENSION 10MM..#1 TO #2 (NEED 5)...... $ 4.73
3R-TB10-7R.......3R BOLT TENSION 10MM..#4 TO #2 (NEED 7)**....$ 15.26
3R-TB10-8R.......3R BOLT TENSION 10MM..#4 TO #1 (NEED 8)......$ 20.95
3R-TB12-2F.......3R BOLT TENSION 12MM..#1 TO #2 (NEED 2)......$ 14.61
3R-TB12-2R.......3R BOLT TENSION 12MM..#4 TO #1 (NEED 2)......$ 31.03
3R-TOWER.........3R TOWER OIL FILTER...W/OIL INLET............$ 42.19
Old Mar 18, 2005 | 09:21 PM
Merovingeon
Veteran: Air Force
sweet!! thanks man!
Old Mar 19, 2005 | 12:12 AM
GtoRx7's Avatar
Collections Hold
That is fat!! Thanks for the info for sure!
Old Mar 19, 2005 | 01:02 PM
Drag'nGT's Avatar
working towards the goal
I'm saving this list. Thanks.
FD7KiD
15
Feb 26, 2021 10:12 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
Brice_Brice
Aug 18, 2015 10:42 AM
FD7KiD
Aug 17, 2015 11:50 PM
