T04E twins replacement
Old Feb 21, 2005 | 12:52 PM
brokenbee's Avatar
Question T04E twins replacement
Looking for theads or thread focusing on a T04E and stock fuel and intercooler.
Old Feb 21, 2005 | 06:58 PM
Manolis_D's Avatar
Going to have to be a bit more specific than that buddy...
Old Feb 22, 2005 | 03:37 PM
brokenbee's Avatar
I only want 300hp out of the engine, and I need to be able to move my car soon. I have PFC, HKS twin power, installed, but I want to run the car with the stock fuel system and stock intercooler. Having a T04e I assumed 1 or 2 people in the past might have run the same setup.
Old Feb 22, 2005 | 03:46 PM
dubulup's Avatar
development
I've only seen one single with stock fuel and IC, it was a greddy kit.
Old Feb 22, 2005 | 04:00 PM
FD3SR1's Avatar
there is a local 3rd gen guy running a t3/t4 with an ss autocrome turbo manifold and the hks fcon he is even running the stock intercooler! last dyno was at 365whp with a messed up turbine wheel at 14psi now his wheel is fixed and it's at 16psi EVERY THING IS STOCK exept the turbo and the fcon! he has about a grand in the mods and he beats motorcycles and v8's all day long im hoping to have it all documented and post more on it later!
Old Feb 22, 2005 | 04:24 PM
2a+RoN's Avatar
i would question how reliable it would be to run 365+ hp@16psi out of a stock i/c...
Old Feb 22, 2005 | 11:10 PM
widebody2's Avatar
addicted to lounge
I think thats right about where the stock injectors are at 100% also
Old Feb 23, 2005 | 08:34 AM
manatecu's Avatar
I predict boom - That will work for a while but not long. The stock intercooler can not remove enough heat to prevent detination. The stock fuel system can only support so much HP before you get more air than gas.
Old Feb 23, 2005 | 05:04 PM
RETed's Avatar
Going back to the original question, you're basically stuck with a T04E "60".
A smaller T04E "57" can get you your 300hp, but you're basically stuck with the same power max as your stock twin turbos.
Run the T04E "60" and turn the boost down - your engine will love you for it.
-Ted
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
