Gettin my J-spec
Old Dec 18, 2001 | 08:28 PM
86Rx7GXL's Avatar
Gettin my J-spec
Hey everyone i have a 87 turbo 2, they just sent my motor out today, The motor is a 89-91 Block but with all 87-88 intake, turbo front cover everything, With getting that is there anything i should pay little more attention to? anything i should watch out for? How do you guys think this motor will run compared to a 87 motor?
Old Dec 18, 2001 | 08:34 PM
RxSeven1's Avatar
i think there is something with the oil metering pump ....series 4 engines are mechanical and series 5 are electrictcal....u gotta run premix or something? help me out here guys
Old Dec 18, 2001 | 08:46 PM
RX-7 GT's Avatar
HyperREV.com
ya, 87'-88's are mechanical omp 89+'s are electrical omp. and you just said you have a 87' turbo.
you also said they are sending you a 89 motor with an 87-88 front cover so he is already set.
it will run better and stronger than a series 4, and a little more power i also know 89+'s have high indepence injectors, diff wiring harness and ecu. so you might need to swap in your old injectors cause your 87' ecu and wiring harness i think will conflict with the 89 injectors.
someone correct me if im wrong.
Old Dec 18, 2001 | 10:43 PM
BLUE TII's Avatar
Rotary Motoring
He said he has 87 intake on it as well, that covers the injectors. Do you mind me asking what shop set you up w/ 89 bock, 87 fornt cover and intake-thats pretty nice. Or did you mean they told you to use these pieces when you put it in? The 89 has higher compression and nicer turbo, but one thing you have to realize is it has dual wastegate passage on turbo 89+ and same spring as 87 turbo (boost over this on stock 89+ is achievced w/ computer boost control). You will not be able to boost over about 7psi w/ out boost controller. Not neccesarily a bad thing.
Old Dec 18, 2001 | 10:45 PM
RX-7 GT's Avatar
HyperREV.com
it doesnt matter what intake he has. he still needs the 87-88 injectors.
Old Dec 18, 2001 | 10:48 PM
BLUE TII's Avatar
Rotary Motoring
It should run a bit better, but one thing to realize about the high compression 89+ motors is that they were able to run this higher compression and boost safely because they upgraded the ECU processor so it was 2X faster in 89. Be very careful running higher boost levels w/ slower ECU as it cannot compensate for factors causing detonation as fast and you have raised the risk of detonation significantly w/ higher compression.
Old Dec 18, 2001 | 10:50 PM
BLUE TII's Avatar
Rotary Motoring
My injectors are in their stock location-on the intake manifold. Where are yours?
Old Dec 18, 2001 | 11:01 PM
RX-7 GT's Avatar
HyperREV.com
dammit don't you listen! i said injectors 87-88 and 89+ are different. 87-88 are low indepence and 89+'s are high. they don't work the high ones (at least not well) with a 87-88 ecu.
they are the same yes all 550cc's.
Old Dec 18, 2001 | 11:07 PM
BLUE TII's Avatar
Rotary Motoring
He said car is 87-one set of 87 injectors there. He said his J-spec is comming w/ 87 intake-second set of 87 injectors there. Where's he getting his 89+ injectors?
Scott 89t2's Avatar
SOLD THE RX-7!
if the shop was smart enough to give him the 87 front cover I'm sure they gave him the right injectors.
you should have used the 89 turbo and manifold though!!!
Old Dec 18, 2001 | 11:12 PM
BLUE TII's Avatar
Rotary Motoring
I noticed that. If he meant to have a "," between "turbo" and "front cover" that may mean he is getting 87 turbo. I hope he meant a "turbo front cover" -whatever the hell that might be, at least it might imply engine still has 89 turbo and mani. on it...:p
Old Dec 18, 2001 | 11:18 PM
RX-7 GT's Avatar
HyperREV.com
yea if they put in the 87 injectors he's fine. no **** i hope they didn't put a pos series 4 on there hehe
Old Dec 18, 2001 | 11:24 PM
BLUE TII's Avatar
Rotary Motoring
Yeah, you hear us 86rxgxl? Tell them you want your 89+ turbo w/ that J-spec! Better manifold, bigger primary scroll passage, and dual wategate passage.
Old Dec 19, 2001 | 05:36 PM
86Rx7GXL's Avatar
Its Japan Direct, They were out of 87-88's so they took a 89+ core and put all 87-88 parts on it. Unfortally they did send me the 87-88 turbo. But im gettin that all for the price of a 87-88. They are sendin the 87-88 injectors so i'll be fine. I was wonding how that motor will run with all the 87 parts on it, thanks guys for helpin out i really dont plan on moddifying it all that much. All i have for it now is a K&N cone filter.
Old Dec 20, 2001 | 01:49 AM
BLUE TII's Avatar
Rotary Motoring
Port that wastegate on the 87 turbo while it is out of car! This is a good safety mod. It will allow you to run low restriction exhaust/intake w/ out raising boost to dangerous levels. More power at stock boost levels!
Old Dec 20, 2001 | 01:35 PM
86Rx7GXL's Avatar
well i got the motor today and what i thought was gonna be great just turn to the worst, all i got is the 89 block and a 87 turbo, that's it, now im missing many parts and knowledge of what goes where and what does what, biggest problem i dont have any gaskets, and i have no clue were all the vacuum lines run i expected a couple days to get it in but now im looking at weeks if im lucky
Also how do you go about porting the wastgate?
Old Dec 20, 2001 | 08:21 PM
importboi22's Avatar
Hks Ownz Me (
where did you get the motor from please tell me not from fc3s.com cuz thats were im gonna get my motor when i get my 89 T2 hopefully!!!
Old Dec 20, 2001 | 09:36 PM
86Rx7GXL's Avatar
nahh i got it from Japan Direct, seems to be a good motor but just dodnt get anything with it
FC_DREAMS
20
Sep 22, 2015 09:43 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
rotarymaz
Nov 6, 2001 11:06 PM
IceMan
3rd Gen Archives
Aug 19, 2001 11:21 AM
