Hylomar question: How do you get it off a machine surface?
Old Feb 18, 2005 | 07:15 PM
Project84's Avatar
Open up! Search Warrant!
I got it stuck to the machine surface where the rotor side seals will be traveling (long story). How do I clean it off? There isn't any sort of cleaning instructions on the packaging.
Old Feb 18, 2005 | 07:20 PM
felixwankel88's Avatar
i used lighter fluid... that stuff removes everything
Old Feb 18, 2005 | 07:31 PM
Project84's Avatar
The only lighter fluid I have is for starting charcoal on fire for cooking on a BBQ grill. Will that work?
Old Feb 18, 2005 | 07:54 PM
RotaryEvolution's Avatar
Sharp Claws
carb or brake cleaner works well.
Old Feb 18, 2005 | 08:00 PM
Project84's Avatar
Thats cool cause my wife threw away the lighter fluid cause there wasn't much left in the bottle.
i would assume the grill fluid will work
Old Feb 18, 2005 | 08:01 PM
hhhehe u posted at the ame time as me, ide just go with the brake/carb cleaner
Old Feb 18, 2005 | 08:10 PM
Project84's Avatar
I used the carb cleaner. Don't have any lighter fluid left. Thanks guys
Old Feb 19, 2005 | 05:47 AM
pengarufoo's Avatar
The mystery of the prize.
if this happens during engine assembly some people just leave the hylomar on the surface though their intention is to get it in the groove for holding the water seals in place.
Lighter fluid / carb cleaner will work but will want to run, you probably don't want to have these fluids in the groove with the hylomar during assembly. A simple way to remove the hylomar from the surface while leaving it in the groove is to just run over the surface with a razor blade. The razor blade approach turns this:
into this:
In little time.
Old Feb 19, 2005 | 02:13 PM
Bob_The_Normal's Avatar
I was going to say razor blade too.
Be careful how you use it though... as soon as you feel it catch on something throw it away and use another one... if you don't apply too much pressure it won't develope a nick but if you do the edge of the groove bends the metal a little on the razor and then you have something that easily nicks and damages the surface.
But it's the best way to clean off the surface.
--Gary
Old Feb 19, 2005 | 02:50 PM
DubbayoC's Avatar
does it really have to be that clean since your gunna coat the rotor housing also?
Old Feb 19, 2005 | 03:29 PM
Project84's Avatar
I got it on the surface of the front end plate and I didn't want the side seals traveling over the sealant, and I wasn't sure how well a razor would get it off because hylomar doesn't harden up like most sealants, it stays tacky. The brake cleaner got the job done.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
joel(PA)
Oct 4, 2015 06:07 PM
musker
Oct 1, 2015 05:58 PM
