Can anyone read japanese?
Old Dec 18, 2001 | 09:15 AM
Rx7-AIII's Avatar
Can anyone read the attached page and tell me what it says. Its a picture file so I can't use tha AltaVista translator. What is the disc made of and is it streetable.
Thanks
Old Dec 18, 2001 | 10:42 PM
Project RX-7's Avatar
Talk to Soul Assasin, he knows Japanese.
Old Dec 18, 2001 | 11:07 PM
Dragon's Avatar
20B N/A Wide Body FC3S
Basicly it says it is a pull type replacement clutch, that will bolt direct up just like the stock clutch... Will have about the same pedal pressure as stock and that It comes with a light weight aluminum 1000kg pressure plate, single metal clutch disk, and light weight flywheel...
I also remeber I read somplace that it is rated at 400hp
Old Dec 19, 2001 | 02:15 AM
Rx7-AIII's Avatar
Thanks Guys
Any indication of what its like on the street? I know its a metal 6 puck.
Old Dec 19, 2001 | 02:39 AM
Dragon's Avatar
It's supposed to be really easy to drive... AND if I can drive around in Japanese traffic all day with a ORC Triple plate solid hub (no dampening springs) cluch that has 2 setting on and off that can hold 1,000 hp before slipping you definitly shouldn't have any problems driving with that clutch...
Just make sure you do a proper break period on it before you start beating on the car, most people don't realize that the clutch will last a lot longer and hold better if properly broken in... Basicly all you need to do is put about 300 miles on it with lots of shifting and don't slip the clutch too much and of couse don't drop it under power...
Old Dec 19, 2001 | 02:57 AM
Rx7-AIII's Avatar
Cheers Dragon
How is Japan?
Old Dec 19, 2001 | 03:18 AM
Dragon's Avatar
Japan is fucken Awsom... except when there is a war going on..
Old Dec 19, 2001 | 03:24 AM
Rx7-AIII's Avatar
Are there any other places to order stuff from out there besides Taka Kaira that are in English.
Old Dec 19, 2001 | 03:29 AM
Dragon's Avatar
None that I know of...
Old Dec 19, 2001 | 03:53 AM
Rx7-AIII's Avatar
Thats what I thought. So much stuff and so few to buy from! You should go into buisness.
pzr2
West RX-7 Forum
Oct 1, 2015 01:26 AM
RedBaronII
Sep 20, 2015 11:29 AM
Matthew Diaz
Sep 18, 2015 03:37 AM
fd3CB
SevenStock Archive
Sep 11, 2015 11:12 AM
