Sponsored by: CARiD
Profec A install help
Old Dec 17, 2001 | 09:40 PM
live4boost's Avatar
AKA ShepFC3
I finally got my Profec A, but I didn't get any instructions with it. I have a 87 TII. I haven't looked at it much, but anyone have tips on the wireing and vac lines. Any help would greatly be appreciated.
Shep
Old Dec 18, 2001 | 12:52 AM
live4boost's Avatar
AKA ShepFC3
DO you only have to wire the power and ground? That looks like the only wires that are exposed. Do you just wire the power to an accesory wire? how bout the vac lines?
Old Dec 18, 2001 | 07:09 AM
Maxthe7man's Avatar
Freedoms worth a buck o'5
You can download and print the instructions from Greddy's website, there are some settings you will need the instructions to adjust properly, and to make it "learn" properly.. What car are you putting in ? it doesn't work that well without a ported wastegate on a TII, even with that it still tends to creep past setpoint.. you will end up setting at .5 bar and it will run 9-10 psi instead of 7, hope it works better with my new wastegate than it did with my stock one..Max
Old Dec 18, 2001 | 07:56 PM
13BAce's Avatar
On a long vacation
Yes, just power and ground. Just hook up the power wire to something that gets +12V when the key is in the "on" position.
1 vacuum line goes to the intake manifold--use the same source that the stock pressure sensor uses. If you're using the stock turbo then the other 2 lines just go inbetween the small hard line coming from the compressor outlet of the turbo and the wastegate.
Old Dec 18, 2001 | 07:57 PM
13BAce's Avatar
On a long vacation
I don't think that Greddy has installation instructions online, just operating instructions. I'm pretty sure that I still have my installation instructions. If anyone needs them just e-mail me at jfrederi@juno.com, and I'll scan them.
Old Dec 18, 2001 | 07:59 PM
13BAce's Avatar
On a long vacation
The vacuum line that goes to the intake manifold comes from the smallest nipple on the stepping motor. I forget which is which for the other 2. One time I forgot and was too lazy to look for the instructions. So I just tried them one way, and it worked. If it didn't then I would have just reversed them.
Old Dec 18, 2001 | 08:08 PM
live4boost's Avatar
AKA ShepFC3
thanks man. I think that I will be able to figure it out. I will port the wastegate when I get the 5series turbo, for now I will deal with creep. So far it hasn't gone past 10psi and it pretty steady curve. 13Bace if you could scan the instructions that would help a lot. If not Im sure I will figure it out. If you can scan them send it to c_shepherd7@hotmail.com or post it here and we can archive it for anyone else who may need it in the future.
Thanks for the help
Oh yeah I noticed there was a forth nipple on the stepper motor. What does that hook up to? The greddy site didn't show anything of it.
Old Dec 18, 2001 | 10:51 PM
Maxthe7man's Avatar
Yes they are there, thats where I downloaded mine from..Max
Old Dec 18, 2001 | 11:46 PM
live4boost's Avatar
AKA ShepFC3
No they're not, trust me I checked. Just operation manual.
Old Dec 24, 2001 | 06:52 AM
Maxthe7man's Avatar
You are not looking hard enough......
CLICK on TECHNICAL
THEN use the PULL DOWN menu for ELECTRONICS
THEN SELECT PROFEC..
It will take you to this page....
http://www.greddy.com/technical/profec_frame.htm
Man, you can lead a horse to water......Max
Old Dec 24, 2001 | 12:06 PM
live4boost's Avatar
AKA ShepFC3
Thanx for the help guys. I found that page, but I was thinking there would be a better one. That will work out fine though.
Thanks again
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
