possible to run with 87 octane if you don't boost?
Old Feb 13, 2005 | 02:14 AM
777fd's Avatar
is it possible to run 87 octane if you stay off the boost and you use the car for commuting on the freeway only? at 70mph for about an hr on the freeway just cruising youre not getting on the boost and since the fd has low compression rotors would it be possible. of course if you boost it will go boom but is there a way you can set it for the wastegate for like 7psi max and just keep off the boost?
Old Feb 13, 2005 | 02:17 AM
TT_Rex_7's Avatar
Again PLEASE SEARCH!
I wouldn't run 87 octane no matter what the conditions are. Stick with 93/91 and just leave it at that. If gas prices are a problem for you, then this is NOT the car for you. These cars normally get shitty gas mileage and require atleast 91 octane.
-Alex
Old Feb 13, 2005 | 02:24 AM
cafe's Avatar
[QUOTE=777fd]at 70mph QUOTE]
Originally Posted by TT_Rex_7
I'm not sure what your speaking of as far as 70mpg,
-Alex
Old Feb 13, 2005 | 02:43 AM
omochi's Avatar
fd-withdrawal
wow did you reazlie you've posted 7 threads in a row??????? :o
Old Feb 13, 2005 | 03:53 AM
scotty305's Avatar
~17 MPG
No!
Old Feb 13, 2005 | 04:08 AM
SiKoPaThX's Avatar
Porque tan serio?
Don't be cheap n00b.
Old Feb 13, 2005 | 04:28 AM
BlueRex's Avatar
Thanks for reading the stickies and searching for yourself before posting
Old Feb 13, 2005 | 07:22 AM
dgeesaman's Avatar
Aside from the fact that it's incredibly stupid, I think it also wouldn't work.
alphawolff
Nov 17, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
Wolf_
Aug 11, 2015 04:23 PM
