Better prepped coupe or convert.
Old Feb 11, 2005 | 01:49 PM
RussinStk's Avatar
Auto-X Junkie
I am still researching building a 2nd gen auto-xer. The 2nd gens with NA 13B now run in F-prepared which has a min weight of 2075 with after market fuel system.
I have seen a fair amount of EP road cars around 2200lbs
Has any one developed a convertible 2nd gen. I would think you should be able to make it lighter then a coupe since you can remove the front windscreen and frame and not mess with the weight of the rear hatch. I would prefer to be underweight, then add weight to balance the car.
Any thoughts?
Thanks
Old Feb 11, 2005 | 02:17 PM
diyman25's Avatar
RE for life
check MAZDATRIX. they have SCCA EP RACE CAR.
From what I know even thought Convertible dont have windscreen and frame and not mess with the weight of the rear hatch. but chassic's sheet metal is much thicker than coupe.
Old Feb 11, 2005 | 05:01 PM
PureSephiroth's Avatar
#1 Certified Cone Killer
the verts are heavier. It is not simply a coupe with the roof chopped off. The chassis was retweaked and remanufactured specifically for the vert model. They are significantly heavier as a result.
Old Feb 11, 2005 | 05:54 PM
RussinStk's Avatar
Auto-X Junkie
Thanks for the info. I understand it not just a matter of chopping the top off. I understand the chassis need to be braced to reduce flexing without the roof structure. With that said, often times in prepared classes which have liberal rules, you can over come model specific issues and create an advantage.
Thanks
Old Feb 11, 2005 | 06:10 PM
Carl Byck's Avatar
Mad Man
Take a coupe, and cut off the roof. The cage take care of chassis stiffness. I think that is what they did on the mazdatrix car. I believe min weight for EP is 2450.
Old Feb 11, 2005 | 06:28 PM
RussinStk's Avatar
Auto-X Junkie
That's a big no no in under the SCCA auto-x rules. You can be protested for cutting the roof off a coupe or sedan. The magic number for me is 2075lbs which would be the min weight for F-Prepared for a NA.
I probably going to start with a fully prep EP road racer. It looks like the most economical and less hassle way to go.
Russ
Old Feb 18, 2005 | 08:32 AM
Travis R's Avatar
trying to build a racecar
The fuel injection penalty is being fazed out over the next couple of years, so you need to be able to get the car down to the class minimum.
Donald Hampton
16
Nov 23, 2022 06:38 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
