CEL : Code 13, intake pres. sensor??
Old Feb 9, 2005 | 09:19 PM
rajeevx7's Avatar
2 FD's since '98
Where can I find this piece, so I can go about changing it.
How pertinent is it really?
Thanks,
Raj
Old Feb 9, 2005 | 09:31 PM
1234rotor's Avatar
GearHeadMoFo
I would check to see if it is unplugged before you go out and buy another one. They are exspensive.
Sometimes the hose will pop off, between the manifold or the sensor, under boost.
It is located just to the left of the brake booster if you are looking under the hood at the firewall. It is a little square box (approx 1"x1.5") with a vacumm hose coming out of the bottom. It also has an electrical connector on it.
Old Feb 9, 2005 | 09:45 PM
rajeevx7's Avatar
2 FD's since '98
That is the boost sensor.
The car isn't idleing like crap at all. I don't think that is the same sensor because I have had that one off before and the car barely ran and backfired like crazy. Those are not the symptoms...today anyway (right).
Raj
Old Feb 9, 2005 | 09:57 PM
rotoboy661's Avatar
map sensor is the pressure sensor
yetter227
20
Sep 5, 2015 11:57 PM
rotor_veux
Aug 23, 2015 09:06 PM
