18x11 rear (FD)?
Old Jan 19, 2005 | 07:31 PM
gfelber's Avatar
18x11 rear (FD)?
Damn, I've a crapload of PMs asking about fitment from this post: https://www.rx7club.com/suspension-wheels-tires-brakes-20/thanks-wheel-suggestions-winner-387407/
Answers: Yes, an 18x11 wheel will fit in the rear using the proper offset, coilovers with 2.5" springs, and tubular trailing arms. This will work with 285 or 295 or 305 rear tires. A 315 may work too, but it'd be damn close.
The trailing arm is the most critical component. My P-zeros, in 295-30 variety have about 3/8" clearance or so.
Offset? Very critical as well. Mine is +48. Any less and you're outside of the fenders, and with more you risk hitting the trailing arm. Could probably get away with +50, but I would say that is max positive offset.
Gene
Old Jan 19, 2005 | 07:42 PM
GOTBANNED?'s Avatar
Boost Addict
wow thats nice..very clean..didn;t think u could fit that much tire under there..must have been alota work tryin to find a perfect fitment..but u had to make tubular trailing arms..or buy? which make?
Old Jan 19, 2005 | 08:08 PM
gfelber's Avatar
Exactly, it's pretty much the max you can get under there. Kinesis was the only wheel manufacturer in the US aside from BBS USA ($1400 per wheel!) that was willing to work with me on various offsets.
Trailing arms are M2s, but they're no longer in business. I think you can get the same diameter arms from Jason or Chuck.
Gene
Old Jan 20, 2005 | 01:48 AM
AMRX7's Avatar
You might have to watch out in hard cornering with the larger tire sizes. I ran 18x10.5's with a 43 offset (more to the outside than yours) and had rubbing problems on the inside fender wall. I have the Rotary Extreme trailing links for extra clearance, but with 305 Hoosier tires in autox, I got a significant amount of inside rubbing on both the trailing arm and inner fender.
With your tire size and just street rubber, you're probably right at the limit.
I did run 17x11's with 315 Kumhos without any problems, but I've rolled my fender lip completely.
-Andy
Old Jan 20, 2005 | 03:49 AM
ARD T2's Avatar
Sorry I posted asking for a link in the other thread. Didn't see this here.
Rishie
Old Nov 6, 2011 | 05:29 AM
jsanti201's Avatar
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
