sbf swap
Old Jan 16, 2005 | 03:04 PM
racing_trends's Avatar
sbf swap
hey guys i have a 1990 Gx and i was wondering i have a spare 302 lying around that i wanna use when my 13b goes, im just conserned im guessing the a carb'd setup will not clear a stock T2 hood? im prolly going EFI any ways but will the ford efi manifolds clear a T2 hood, i just wanna make a sleeper with out going cowl
Marcello
Old Jan 19, 2005 | 10:40 PM
QuasiMofo's Avatar
eVilallianceracing.com
If you use a Weiand 8011 intake and a low profile air cleaner a carb setup should work
OR if you use an Edelbrock 7123 5.0L manifold if you want injection
Both are among the slightest of stature.
Old Jan 27, 2005 | 09:05 PM
gammey4's Avatar
ive got a 302 in a non turbo rx7 2nd gen and the distributor doesnt clear the hood, the carb isnt even on yet. just a heads up.
Old Jan 29, 2005 | 01:07 PM
oh geese,
this isnt looking good, i love Rx7's to death but i am really against a cowl induction hood on it
Is there any way to lower the engine more in between the frame with shorter frame mounts? but there might be a problem with oil pan clearence as well, anyone else have any more info?
Marcello
Old Jan 29, 2005 | 08:00 PM
andrewb70's Avatar
LS1
Andrew
Old Jan 29, 2005 | 09:13 PM
screw that old remake of the fe ford engine and stick with the real ford engine.. that's where it's at!
Old Feb 7, 2005 | 02:32 PM
defadus's Avatar
spacer sub frame
I have a 5.0 in an FC. You will have to use a low profile intake as said before. Carbed - Edelbrock Performer or similiar, EFI - the one listed might work, I know a stock 94-95 Mustang or 89-91 Thunderbird intake will clear. To get the distributor to clear spacer the sub-frame down a 1/2". I cut 4- 1/2" thick pieces of flat bar and drilled holes in them. Dropped the sub-frame down, placed spacer over spuds( I think that's what they are called) and raised the sub-frame. Spuds(?) are long enough for 1/2" spacer but, not much more. Everything will clear under stock hood. Some trimming will still be neccessary on bottom of hood.
ChrisR
Old Feb 7, 2005 | 04:47 PM
owen is fat's Avatar
sPuds.... = sTuds?
Wehavetocook
Sep 23, 2015 11:04 PM
gtcd
Sep 17, 2015 01:15 PM
gabescanlon
Sep 15, 2015 06:57 AM
jakeishness
11
Sep 11, 2015 11:33 AM
