Sponsored by: CARiD
13B Rotary 1984-85 RX7 GSL-SE
Old Jan 15, 2005 | 10:28 PM
Imagination's Avatar
Gettin my whip runnin =)
HI i just joined,
and i have a blown rotary my engine is a 13B. My car is a 1985 RX7 GSL-SE and i was wondering is there a place i can buy rotary engines or rebuilt engines? on the internet or should i just have the mazda dealer fix it. But i dont want to pay $5000 for them to do it if the engine doesnt cost that much cause i can put it in myself
Old Jan 16, 2005 | 03:11 AM
neit_jnf's Avatar
http://rotaryresurrection.com/ for low budget rebuilds
there are many more and cost varies depending on what you want done in terms of performance
the SEARCH button is your friend
Old Jan 16, 2005 | 12:04 PM
thanks for the link
ill try the search now I want to see what engines i can put in my rx7 before i dish out the money for a rebuild
Old Jan 16, 2005 | 01:42 PM
diabolical1's Avatar
if you feel up to undertaking the rebuild for yourself, i'm sure you'll get a lot of support on this board. i can speak for myself that i'll help you as much as i am able.
check out the archives of this section, there is a good start on some useful rebuild info. also ... you may want to check out www.nopistons.com there is great rebuild support there as well.
oh ... and welcome to the board.
Old Jan 16, 2005 | 04:15 PM
how hard is it to rebuild the engine myself ?
can you give a general idea of what tools i will need...
thanks for taking time to go over this with me
Old Jan 16, 2005 | 04:41 PM
well ... "hard" is a relative term, so i'll say this. if you have patience and can follow directions pretty well. it won't be hard at all ... time-consuming, maybe, but not hard.
as long as you have a quality wrech and ratchet/socket set (metric), you have most of what you need. special tools are: torque wrench, something to lock the flywheel, something to pull the 52 mm flywheel nut, and something that can twist 300 ft-lbs "ON" and "OFF".
Old Jan 16, 2005 | 05:51 PM
TwinTurbo'D's Avatar
RX-Shun
a good place to look for information about ur car is the first gen section. There are very knowlegable people on this forum, along with bunches of crap. For the most part this is a great way to learn about ur car
Old Jan 16, 2005 | 09:15 PM
thanks for the reply
im gonna start the rebuild process or swap a 12A into it i have a running 12A on a horse
Until i rebuild the 13B
Old Jan 17, 2005 | 07:02 PM
Power Aids's Avatar
can you get re-maned 12a's?
i'm pretty sure you can get 13b's still.
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
