442 rwhp--New Dyno Results
Old Dec 29, 2004 | 10:03 PM
Green Spyder's Avatar
I tuned & dyno'd at 3000 miles after the rebuild (407 rwhp at 14psi), and at 7500 miles, she was starting to run pretty crappy, so back to the dyno for a little more tuning. So after a little more break in, and a throttle body modification (Brian's TB mod) we got 442 at 14 psi. Below is a list of my mods:
1979 Triumph Spitfire
Project link:
http://www.home.earthlink.net/~ricgibson/
1988 S4 13BT drivetrain includes:
Haltech E6K
Turbonetics T04 60-1 w/.84 a/r divided p-trim turbine
50 mm HKS external wastegate
Greddy ProfecB boost controller
720cc/min primaries, 1600cc/min secondaries
Walbro high flow fuel pump in 15 gal ATL fuel cell
AEM variable rate FPR
12" X 18" X 4" Spearco FMIC
Ported Throttle Body Modification
Street Ported, FD seals
65 psi oil restricter
18lb Flywheel w/ACT 6 puck clutch
1987 RX7 rear end subassembly (w/LSD & independent suspension)
Suspension mods include:
Custom 2" square chassis
8" wider track
Coil over Koni's all four corners (adjustable shocks)
Adjustable spring perches (fast spring changes)
Adjustable upper/lower control arms
1997 Camaro Z28 rack & pinion (very close ratio)
1993 RX7 front brakes & rotors (11" with 4 piston calipers)
1987 RX7 rear brakes & rotors (11" with 2 piston calipers)
Front/Rear brake biasing controls
Curb weight 2200 lbs
Corner weight link:
http://home.earthlink.net/~rgibsonsp...rnerWeight.jpg
442 rwhp/350 lb ft torque
Dyno Sheet link:
http://home.earthlink.net/~rgibsonsprint1/CarDyno.htm
POWER/WEIGHT RATIO = 5 lb/hp
Old Dec 29, 2004 | 10:52 PM
casio's Avatar
casio isn't here.
nice! i believe i remember that engine. in fact i have plenty of pictures of it if its the one i'm thinking of. its the one that was painted british racing green, right? i remember brian having to fly out to colorado due to a problem with the extra dowel pin not letting the engine seal properly. nice numbers!
Old Dec 29, 2004 | 11:07 PM
Wargasm's Avatar
Weird Cat Man
Good numbers, but I think your boost reading is off or something......
The reason I make this comment is because on your 6 psi pulls on Apr 24 and Dec 21, you've got around 200 lbs-ft at 5500 and about 300 peak rwhp.
Your more recent graph shows a 442 rwhp and a 368 rwhp run... at 14 and 6 psi.. ??? Somehow you pulled out 300 lbs-ft of torque at 5500 rpm at 6 psi? That's 50% more torque from tuning alone! My guess is that would be around a 10 PSI pull.
I am not trying to start a battle, just trying to make sure we've got the right boost level. Can you double check it?
Thanks,
Brian
Old Dec 29, 2004 | 11:19 PM
I don't think the boost controller was changed (low boost setting), although I suppose it's possible...we didn't do a data log on that dyno pull. The boost guage on the dash is attached to a different (probably less accurate) place on the manifold than the Haltech...it showed 6-8 psi on that particular pull.
We did, however, do a data log on the 14 psi pull, so I'm pretty certain that the big power pull is accurate, which is really all I'm showing off here.
As far as starting a battle, you know me better than that...when flames get thick I just smile and quit posting (hence the low post numbers).
Old Dec 30, 2004 | 12:51 AM
ls1hybrid's Avatar
that ******* impressive, nice weight too. got any times?
Old Dec 30, 2004 | 01:38 AM
got any times?
Not yet...I'm getting custom racing wheels made, then finding a good set of slicks before I run the quarter mile.
I may not get many chances at it, Bandemere won't let a convertible car without a full racing cage run if below 11 seconds. I'd like to get my traction/launch control hooked up first, should lower launch times...
Old Dec 30, 2004 | 09:07 AM
Wargasm's Avatar
Weird Cat Man
Yes, that 14 psi pull is sweet! I have a very similar turbo except with a 1.00 A/R... I can only imagine how that car must move since it weighs about nothing! hehehehe
Old Dec 30, 2004 | 09:09 AM
Wargasm's Avatar
Weird Cat Man
I'm also curious to know your timing numbers at the 14-15 PSI range. How much split do you run? I run about 15 deg leading timing with a 18 degree split at 14 PSI. I am running a bit richer than you at about 10.8-11.2 AFR in that range. Got any pictures of your porting?
Old Dec 30, 2004 | 10:52 AM
Wargasm's Avatar
Weird Cat Man
What trans is that? The FC non turbo box? I hope it holds together
Old Dec 30, 2004 | 11:52 AM
Kingofl337's Avatar
Letting the Smoke Out!
well it says S4 BT drivetrain. I would assume its a BT tranny. I'm 100% sure a stock N/A tranny would have insinrated at those numbers.
Old Dec 30, 2004 | 01:24 PM
Kahren's Avatar
i am not a girl
nice numbers but 12:1 afr is kinda lean esp for that much power
Old Dec 30, 2004 | 01:47 PM
Parastie's Avatar
Mountain Rotary Mod
Bah! I've been trying to get Rx7 guys to meet and you have such a beautiful car and never came for a visit! You should visit the regional forum every now and then! Awesome car!
Old Dec 30, 2004 | 02:38 PM
BDoty311's Avatar
88 AE
Awesome numbers, very similar setup to mine, except you put down 30 more horses. But then again my car was dyno'd on a very hot and humid day, that could be the cause.
BTW- I love your car, nice creativity.
Old Dec 31, 2004 | 09:41 AM
Wargasm's Avatar
Weird Cat Man
Added your car to my dyno page.... see my sig for the link
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Rotate86
May 18, 2018 02:44 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
