difference between s4 and s5 lower intake manifold??
Old Dec 29, 2004 | 06:07 PM
KompressorLOgic's Avatar
I
Lightbulb difference between s4 and s5 lower intake manifold??
ok i am doing a custom "5th and 6th port" opening mod on my s4, i have a spare s5 manifold sitting around,
i am using the electric choke from a first gen rx-7 ( the one that opens when u are cranking the starter only) and an rpm switch. i noticed that these work alot like a solinoide, i also noticed that once it stops moving that there is a sort of clutch asembly inside that makes it so the motor will spin freely and not jam and over heat.....
i am going to have to make some sort of fancy confangled bracket of some sort..... i know the actuators are oposite for open and closed in the s5
but i am wondering if the screw holes and the actaul actuator sleeves,little pivot thingy, them selves are in the same location so i can creat my custom bracket to mount then? with out having to take my s4 manifold off....
ill post some picks of my different method
C. Ludwig
Jan 30, 2019 06:31 AM
86glxNA
Aug 22, 2015 08:54 PM
