Dowel Pinning Cost
Old Dec 29, 2004 | 04:00 AM
nkeehn's Avatar
Dowel Pinning Cost
Hey,
What's a good place to get dowel pinning done and how much does it cost?
Thanks,
Nick
Old Dec 29, 2004 | 08:43 PM
680RWHP12A's Avatar
email me for a price
robert@rotaryshack.com
Old Dec 30, 2004 | 01:45 PM
nkeehn's Avatar
bump
Old Jan 1, 2005 | 09:45 AM
ronbros3's Avatar
ronsperformance.us or 386-253-0383, $300 daytona fl.
Old Jan 1, 2005 | 12:56 PM
hondah8er's Avatar
mazdaspeed 3 coming soon
Can't you post your price so everyone knows?
Old Jan 3, 2005 | 04:59 PM
680RWHP12A's Avatar
i cant put prices on the forum, cause i get in trouble
Old Jan 3, 2005 | 05:24 PM
hondah8er's Avatar
Fair enough...just asking
Old Jan 4, 2005 | 02:26 PM
13btnos's Avatar
Dowell Pin Alternative
Mazdatrix now offers full stud kit and the machining for $950.00USD. This is the stud kit offered by Xtremerotaries & Guru Motorsports from Australia a lot better than machining extra dowell pins. Everyone on the West Coast southern CA to be exact wants $1000.00USD to add extra dowell pins to a motor. Believe me I've called around and asked a lot of shops. I don't work or am associated with Mazdatrix but I am sending my motor to them to get the stud kit done to it.
Old Jan 4, 2005 | 03:28 PM
680RWHP12A's Avatar
i know 2 people that purchased the stud kit and still cracked thier motors!!!
the stud kit helps alittle but the ultimate way to keep your motor from flexing, and or cracking is to add x-tra pins
Old Jan 4, 2005 | 03:50 PM
13btnos's Avatar
Did they use the standard stud kit that requires no modification or the oversized stud kit that requires you to get it tap, drilled, and reamed? Because the oversized set makes each bolt act like a dowell pin. And I know it works because I have a friend in Florida that uses them at 42# of boost no problems so far.
Old Jan 4, 2005 | 05:33 PM
hondah8er's Avatar
does somebody have pics of the dowelling process? I'm not quite too sure what it entails exactly.
Old Jan 4, 2005 | 06:45 PM
RotaryWeaponSE7EN's Avatar
I dont even know what it does, would someone mind posting more details.
Old Jan 5, 2005 | 09:20 AM
Tim Benton's Avatar
FD title holder since 94
doweling in SoCal - $1000.00
stud kit at RB - $950.00
$50 isn't much of a difference. The doweling kit means your adding to the existing engine bolts. The stud kit means take existing bolts, massage the block a bit and use bigger, stronger bolts. Is that what it mean? trying to clarify for me and other people.
Tim
Old Jan 5, 2005 | 05:27 PM
ronbros3's Avatar
HEY i must be way to low on my pricing ronsperformance.us 386-253=0383. I didnt know you cant post pricing, but I specific ordered custom drills and end reamers for the dowels,so far so good. I use a large vertical mill, engines run fine so far, but low boost , 20-25psi. I believe mazdas where made to be flexible and we are trying to make them solid, remember exploding cannon ***** were solid steel hollowed in the middle filled with gun powder a small fuse lit it off! BANG it exploded pieceswent in all directions. anyway we have a job ahead. RON
Old Jan 5, 2005 | 05:33 PM
ronbros3's Avatar
check out dowel pinning cost on the site
Old Jan 5, 2005 | 06:15 PM
13btnos's Avatar
Tim
Look at this http://www.nopistons.com/forums/inde...44016&hl=dowel
And also look at this http://www.xtremerotaries.com/
Old Jan 7, 2005 | 05:32 PM
Tim Benton's Avatar
thanks for the links.
Tim
Old Jan 8, 2005 | 05:25 PM
nkeehn's Avatar
ok, here's an application for everyone to argue over... I'm building an turbo 13b which should only see 400hp in it's life time. It's built out of spare parts so cost is an issue. What's the best solution?
renjiv2
57
Jan 25, 2024 03:34 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Coochas
Oct 3, 2015 04:49 AM
NickNac113
13
Oct 1, 2015 09:25 PM
