Uh.. i was sitting at the drive-thru
Old Dec 29, 2004 | 01:39 AM
TiGeRC|aw's Avatar
anyways i was sitting at the del taco drive thru and then my passenger is like there's smoke coming out of your car and i was like where? i looked down and it was coming from the shifter.... it was raining so maybe some water splashed up and hit the tranny so smoke went up it through the shifter or what?
Old Dec 29, 2004 | 01:48 AM
SonicRaT's Avatar
Super Raterhater
depends on the duration of the smoke, chances are you've got an exhaust leak of some sorts, and your shifter boots are all missing/destroyed.
Old Dec 29, 2004 | 02:41 AM
Rx7MPGUY84's Avatar
Rpm abuser
boots on ur shifter are 9/10 shot or not there at all. Since it was raining maybe some water got on ur exhaust and steamed or sonicrat is right and u have a massive leak.
Old Dec 29, 2004 | 03:11 AM
BlaCkPlaGUE's Avatar
I live in an igloo
naw, I still think its becuase he was shifting so fast that it smoked.
Since you just noticed this, and it happened to be raining, I bet it was steam off the pipes.
Old Dec 29, 2004 | 12:47 PM
wozzoom's Avatar
"Mmmmmmmmmm... Del Taco"....
God I miss that place.
Oh yeah, check your shifter boots.
Old Dec 29, 2004 | 11:56 PM
vintagespeed's Avatar
Why is it that so many people confuse SMOKE with STEAM?
You see, steam is produced from water evaporating (vaporizing) at a high rate. Kinda like clouds in reverse. Steam doesn't smell bad cause it's just water.
Now smoke on the other hand, is something BURNING. It's usually oil, paint or wiring burning on a hot exhaust (usually the manifold) which produces noxious gasses (smoke). Just like what comes out of your bowl when you light it.
Exhaust fumes will get you high and eventually kill you if the concentrations are high enough. If your car is leaking enough exhaust into your car that you can SEE it, then you probably cant hear yourself think cause it'd have to have a serious hole/crack somewhere near the shifter. Not likely.
So, if the "smoke" coming up from the rotted shifter boot smelled horrible and made you roll the windows down then it's probably a problem. If the "smoke" didn't fill the car with an aweful stench (smell) and didn't get you high, then it's most likely just steam from wetting down the exhaust coming through the gutter into Del Taco.
Damn I need a macho nacho.
-jb
Old Dec 30, 2004 | 12:02 AM
felixwankel88's Avatar
hahah did u get that from a dictonary lol j/l i would say the shifter boot
Old Dec 30, 2004 | 12:13 AM
RotaryEvolution's Avatar
Sharp Claws
i would probably look for the source of the smoke, but that's just me...
Old Dec 30, 2004 | 12:48 AM
ls1hybrid's Avatar
what the hell is del taco? Im here in san antonio and have never heard of this fast food place!
Old Dec 30, 2004 | 12:51 AM
Green Spyder's Avatar
I was taking a friend for a quick run on the highway to show off my car at 14 psi at WOT, was just letting off on the throttle, and the smell of fuel permeated the cabin, just as he says "Hey, my feet are getting wet!" The fuel rail/FPR bolt was very loose and spraying fuel all over the turbo exhaust, and some got in through the firewall. Damn lucky I didn't need to use my fire extinguisher, just the cresent wrench I keep in the trunk. It melted his rubber flip/flops.
Old Dec 30, 2004 | 02:38 AM
TiGeRC|aw's Avatar
-jb
ya ya steam comes from water but i wasn't sure it was from water so it could of possible been " smoke " but the del taco aroma had filled my car so i couldn't tell if i was getting high off the food or " smoke / steam ". anyways i got owned so ya =[
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Robrods64
Oct 2, 2015 07:56 PM
dexter snoek
Sep 29, 2015 09:18 AM
