Info On A Bac Valve......
Old Dec 27, 2004 | 12:00 PM
joel91's Avatar
Question Info On A Bac Valve......
I Just Need To Know Is It Possible For A Bac Valve To Leak Coolant Down Into The Engine??? I See A Coolant Pipe Above The Bac But Is That A Closed Pipe Or Does That Run Down Into The Bac Assembly??? I Have A 91n/a....any Ifo On This Anyone?
Old Dec 27, 2004 | 12:05 PM
SureShot's Avatar
Seduced by the DARK SIDE
The coolant runs through a separate casting attached to the BAC.
There is no coolant passage into the BAC.
Funkspectrum's Avatar
that coolant hose has nothing to do with the BAC valve
Old Dec 27, 2004 | 12:06 PM
dammit SureShot....posting at the same time as me!!
Old Dec 27, 2004 | 12:14 PM
SureShot's Avatar
No worries - Now if we could just figure out why Mazda did that.
Maybe just to keep the hose from flopping around?
Maybe to cool a hard working BAC in a summer traffic jam?
Old Dec 27, 2004 | 12:39 PM
13bpower's Avatar
s4 for life
Actually the opposite, the coolant passage is there to warm a frozen BAC in the winter.
Old Dec 27, 2004 | 01:08 PM
pmr2000's Avatar
Could the BAC freeze? Isn't just a electrically operated valve?
Old Dec 27, 2004 | 02:20 PM
Turbonut's Avatar
Originally Posted by NZCONVERTIBLE
This is one of those old wives tales Aaron mentioned. If the BAC valve is so cold it can freeze, then the engine is obviously not running, in which case the coolant will be just as cold as the BAC valve.
More works of wisdom from our friend from New Zealand!
Old Dec 27, 2004 | 03:13 PM
SureShot's Avatar
I can see condensation icing being a factor under some conditions in an NA, but not a turbo.
The aircraft guys can tell all about that.
Old Dec 27, 2004 | 03:27 PM
joel91's Avatar
thanks guys for the info....
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
Rotafuzz
Sep 30, 2015 09:55 AM
