Sponsored by: CARiD
Racing Tranny?
Old Dec 10, 2001 | 01:24 AM
funscooby's Avatar
Racing Tranny?
I have heard of a few trannys being used with rotaries like the Jerico,etc I am curious if they are direct bolt or an adapter plate is needed.
Thanks
Old Dec 10, 2001 | 08:37 AM
tims's Avatar
only "bolt on" "racing" type trans available for any rotary is the Mazda Motorsports trans built by PBS. I am not sure of the price or availability. Quaife makes a dog ring gear set for the turbo II trans that is available from Trust in Japan for about $6300. Jericos and other domestic transmissions can be used with an adapter and an old RX4 bellhousing(not the easiest thing to find in the US). plus shifter location will need to be revised, cooler will need to be installed, custom drive shaft built, custom clutch built. I have been thinking of this setup for my race car but there are alot of things the work out and develope, but yes it can be done.
Old Dec 14, 2001 | 06:38 PM
Probably the pbs transmision is the best on the market, for the rx7, the gears can be change with out disasemblying the transmision , and there are several ratios you can get, the only factor is the money, it goes for 8grand.
also from www.housemanautosports.com you can get a close ratio racing straight gear set , installed in your transmission, this for the price of 5,500dls.
Pedro.
Old Dec 15, 2001 | 03:37 PM
Evil Aviator's Avatar
Rotorhead
The PBS, Zanes, and HKS bolt right up to the engine. I'm not sure about how they fit into the different generation transmission tunnels, but the PBS requires some modification on a 1Gen. The PBS can take the least torque of the 3, but will be fine if you have an EP or GT car. Other racing transmissions like the Jerico, Lenco, T10, and T56 require an adapter. Most dogring transmissions sell for about $7K USD, while the T10 & T56 are about $2K.
Old Dec 15, 2001 | 08:09 PM
do you have a web page for the zanes, lenco,T10 and T56, this last 2 aren't straight gear racing transmision?
Old Dec 15, 2001 | 11:40 PM
Rotorhead
The T-10 is available in both helical and spur gear types, and is availble with dog rings. The higher-end Richmonds will run around $5-6K. You may be able to get straight-cut gears for the T-56 somewhere, but I'm not sure.
The Lenco ST1200 is for drag racing, but can also be used on the street. It won't work well for road racing because it is not capable of compression braking.
http://www.lencoracing.com/
T-56
http://www.ttcautomotive.com/products/tremec/t-56.htm
http://www.fortesparts.com/tremec/
T-10
http://www.richmondgear.com/
Zanes Transmissions
Horacio O Ferrea
North America Division Inc
2600 NW 55th Ct
Fort Lauderdale, FL
(954) 733-2505
Old Dec 18, 2001 | 06:56 AM
5 SPEED RACE TRANSMISSION
AFTER 2 YEARS OF R AND DWE HAVE A FINISHED MANUFATURING A 5 SPEED CLOSE RATIO STRAIGHT DOG TRANSMISSION , WHICH IS A DIRECT BOLT INTO ANY TURBO CASED MAZDA HOUSING IT HAS BEEN REALIABLE IN 600HP CIRCUIT RACE CARS THE PRICE WILL BE UNDER 5K US
Old Dec 19, 2001 | 12:23 PM
Rotorhead
Re: 5 SPEED RACE TRANSMISSION
Who is "WE"?
BTW, the Caps Lock key is on the far left side of the keyboard.
Old Dec 19, 2001 | 06:28 PM
mmaragos's Avatar
Check it here...ROHAN posted...
http://www.rx7forum.com/showthread.p...threadid=39610
Old Dec 19, 2001 | 06:56 PM
SuperchargedRex's Avatar
Chief Knucklehead
Not sure if this is what you're looking for...
Check out Quaife's 6 speed dog engagement gearkit, here's what they wrote to me:
Thank you for your inquiry. The 6-speed dog engagement gearkit is for the 3rd and last generation of the RX-7. The ratios that are listed are the only ratios that have been built at this time. Alternative ratios can be made but must be ordered in quantites of at least 10 units, not real practical for the average non-trade customer.
The taller 1st gear was made to enhance traction off of the line and also to make 1st gear usable on the race track or autocross course where the stock ratio 1st would not be.
Again, an alternative ratio 6th gear could be made to your requirements, but the cost for a "one off" would be price prohibitive. Please bear in mind that this gearkit is for competition use only and is not suitable for the street.
And some info off their website:
GEAR RATIOS
1st 2.823
2nd 1.941
3rd 1.513
4th 1.200
5th 0.958
6th 0.780
$6,495.00
cleann88
Jan 15, 2022 11:28 AM
sinclair7seven
11
Sep 11, 2015 10:15 AM
