RRFPR Install
Old Dec 10, 2001 | 12:19 AM
machinehead's Avatar
kortez
RRFPR Install
I am getting ready to install my SX RRFPR and was just wondering if someone that has done it before can hook me up with some quick install tips. What lines need to go where ect.? Also do I need to remove my stock regulator and block it off or can I just leave it there? It is adjustable also so what is a good place to set my base fuel pressure at?
TIA
Cliff
Old Dec 10, 2001 | 06:22 PM
FastX7's Avatar
Check out Rob Robinette's site, he has a How-To on installing an aftermarket FPR.
Old Dec 11, 2001 | 12:19 AM
kortez
I checked it out but he says nothing about the extra line fitting. My regulator has 3 fittings, 2 inlets and 1 return. I guess I should just block off the extra one?
Is it absolutely mandatory that I remove the factory regulator? I am sure this is a dumb question but won't this one just over ride the stock one?
Old Dec 11, 2001 | 06:41 AM
FastX7's Avatar
The factory one gets replaced, so you don't have to keep the stock one around. I'm not sure what to do with the extra nipple as I don't have my FPR yet. That should be the line that connects to the turbos and tells the FPR when there's boost so it can raise the FP. Correct me if I'm wrong...
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
