aeromotive pump hookup
Old Dec 9, 2001 | 08:56 PM
Marcel Burkett's Avatar
Question aeromotive pump hookup
Any body tried using an Aeromotive 1000hp pump in series with the stocker ? , I plan to do so using a -6AN line on the suction and a -10AN line on the discharge . The pumps are controlled by a HALTECH E6K (on at 5000rpm and 0 map.),and are to feed 850cc primarys and 1300 secondaries.
Old Dec 9, 2001 | 09:46 PM
Greg's Avatar
Re: aeromotive pump hookup
Island Boy!!! welcome to the board
Old Dec 9, 2001 | 10:41 PM
Greg's Avatar
you are planning on using the stock fuel pump and an aeromotive ?? I think it would be a better Idea to just sump the fuel tank and run just the aeromotive pump.
Old Dec 10, 2001 | 01:20 AM
crispeed's Avatar
'Tuna'
Due to the design of the Aeromotive pump you cannot place an inline pump on the inlet! The Aeromotive's are high volume pumps and require at minimum #10 fuel ines on the inlet to perfom at their best. The only way you can run a pump inline before the Aeromotive would be to feed a surge tank from which the Aeromotive would then pull from. As Greg said before the best way would be to use a sump.
crispeed
87TII
9.20@150mph
2600lbs
Old Dec 10, 2001 | 01:25 AM
crispeed's Avatar
'Tuna'
Re: Re: aeromotive pump hookup
YEH!
Welcome Trini Massive!!
crispeed
Old Dec 10, 2001 | 05:24 AM
Question Installing a sump
I know what is a sump ,but where can i get one ?, are they available prefabricated ?, how difficult is it to install ? , can i just weld in a fitting at the bottm of the tank?.
Old Dec 10, 2001 | 07:20 AM
Greg's Avatar
Re: Installing a sump
There are a few places that sell the box (welded triangle and the AN fittings) for around $50-75. I will have to look for one online and post the link. Other than that, all you have to do is cut a square out of the bottom rear of the tank and weld the "box" in. Its pretty easy once you have the already fabricated "box" but if you are gonna do it from scratch its kind-of-a pain in the culito. By The Way what year car do you have and what turbo setup?
Old Dec 10, 2001 | 11:14 AM
crispeed's Avatar
'Tuna'
Re: Re: Installing a sump
Here's a little tip!
Instead of cuttting a square out it's much better to cut a couple of holes out with a hole saw so that when you brake the sump would always remain covered with fuel. That's the proper way to do it especially for a street car.
crispeed
87TII
9.20@150mph
2600lbs
Old Dec 10, 2001 | 11:22 AM
Greg's Avatar
Cool,I will remember that in case I get a street car How are the laws in Trinidad with Fuel cells? Are they street legal?
Old Dec 10, 2001 | 06:49 PM
Taz's Avatar
Taz
http://www.summitracing.com
part #CEE-4040
Old Dec 16, 2001 | 06:47 PM
Question Gas tank sump
Has anyone sucessfuly made and installed a sump on their gas tank?,if so what are the dimensions and do you experience any clearance problems ,seeing how low these cars are.
Old Jan 3, 2002 | 10:41 AM
Talking Thanks Guys
I installed a sump and all my problems are gone,It launches soo hard that the low level light/alarm on my brake reservoir comes on and stays on till I'm gone!!!!!.
Old Jan 3, 2002 | 10:59 AM
crispeed's Avatar
'Tuna'
Hey Marcel!
I've also seen some people mount the pump in the tank!
crispeed
87TII
9.20@150mph
Old Jan 3, 2002 | 06:16 PM
Talking Is So ? !!!
So y yuh eh tell meh so eh ? , ah woulda tri it !! (Trini dialect) , meaning ,so why didn,t you tell me so ,I might have tried it .
Old Jan 3, 2002 | 07:14 PM
crispeed's Avatar
'Tuna'
Re: Is So ? !!!
Boy tha reason y I eh tell yuh was because meh brain bazodee!
Plus I eh sure that the Aeromotive can be mounted in tank like the Paxton pumps!
Suppose yuh did put it in d tank and it blow yuh *** up all d way to Mt Saint Benedict, yuh woulda cuss meh *** if yuh didn't dead! HE HE HE!
crispeed
87TII
9.20@150mph
Old Jan 4, 2002 | 11:39 AM
Talking All rite boy ah understan yuh
Tanks all de same........Like yuh from dong here o watt ? !!!!
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
t-von
Sep 10, 2015 01:56 PM
