How much Vacuum you guys got?
Old Dec 9, 2001 | 04:42 AM
ROSHX7's Avatar
Lightbulb How much Vacuum you guys got?
How much VACUUM do you guys have at IDLE on your TIIs? I am worried mine is too low. Right now, at 800rpm I get 11. Is that the right amount? Also is it possible NOT TO SHOW A VACUUM LEAK AT IDLE, but it can HAPPEN under driving acceleration?
Old Dec 9, 2001 | 06:57 AM
HAILERS's Avatar
HAILERS
14 in/hg at 750rpm on a 87turboii. My 87na gets 16 in/hg at 750. Always puzzled me, the difference. Lower compression ratio on the turbo make a difference? Don't wanna hear anything about it being a worn out engine. Its possible to have a vac leak that is not detectable using normal methods. The egr diaphram could be ruptured internally and causing a vac leak and so could the switching diaphram in the acv(be busted and leaking causing a vac leak).
Old Dec 9, 2001 | 07:14 AM
1FastT2's Avatar
I have about 11 but im kinda thinking my engines about to take a ****.
Old Dec 9, 2001 | 09:08 AM
C. Ludwig's Avatar
www.lms-efi.com
My 90NA pulled 15 @ idle.
Chris
Old Dec 9, 2001 | 09:35 AM
17-18 inches,
depeding how rich or lean i make the mixture, also how much timing advance I give it. I have a haltech which lets me do that. I also have a brand new rebuilt.
C
Old Dec 9, 2001 | 11:29 AM
Gene's Avatar
10 lb. boost, 5lb. bag
My T2 does about 13 at idle I think (and it idles a little low, about 700)
I think the reason vacuum is less on a T2 is because the turbo is spinning just a little bit, and lessening the vacuum effect. or something
Old Dec 9, 2001 | 12:01 PM
Brian P's Avatar
I get between 15~17" depending on if the car is warm or not.
Old Dec 9, 2001 | 12:25 PM
Geoffman72's Avatar
16-18 @ 750rpm on 87 TII with 90k on original engine with leak between upper and lower intake
Old Dec 9, 2001 | 12:58 PM
Scott 89t2's Avatar
SOLD THE RX-7!
should be between 15 and 20. if it's lower then 15 you either have a vac leak or your engines almost dead.
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
