Air Pump Diagnosis
Old Dec 8, 2001 | 06:29 PM
Air Pump Diagnosis
High Ya'll,
Think my air pump is bad. It's got 140 grand on it, so I think you could carbon date it. Anyways, how do you check it? Any help would be great. Alan.
Old Dec 8, 2001 | 07:14 PM
Mahjik's Avatar
Mr. Links
Re: Air Pump Diagnosis
Originally posted by ALANB.FD3
High Ya'll,
What symtoms are you having to make you think your air pump is bad? Strange sounds?
Old Dec 8, 2001 | 10:12 PM
mine has 108 K on it and it finally seized today. It was making wierd loud chirping, squealing noises for a couple days and then finaly today..I was looking at it and wola!!! it stopped, so I shut the motor off right away...luckily I was waiting for it to die while in my drive way....
Old Dec 8, 2001 | 11:50 PM
Mahjik's Avatar
Mr. Links
I had something similar, mine was making noise after the car warmed up, but it turned out to be a bad hose, not the air pump.
This is why I was asking this guy what his symptoms were.. I might just be a hose connected to the air pump, not the air pump itself.
Old Dec 9, 2001 | 03:39 AM
rx7_lover's Avatar
i think mine is dead.
of course the belt is running through it but the center part ( where a bolt is located in the center of pulley) doesnt move at all.
if i remember correctly, air pump is supposed to work below 3000 rpm. and that includes when idling.
anyway, i just bought a n-tech hi-flow cat and an used air pump that has 45k on it.
just making sure, the center part (the bolt area) is supposed to rotating along with the pulley at idle, right?
thanks in advance
Old Dec 9, 2001 | 07:16 AM
No weird noises, exept for an occasional click. I think thats the clutch engaging and disengaging. My exhaust always smells like sulfur and someone told me that could be from a failed air pump. I guess I should replace it anyhow. I found one on here for 75 bucks. Oh, I have the Bonez High Flow Cat....that might have something to do with it.
Old Dec 9, 2001 | 12:37 PM
thanks in advance
I can't remember whether the centere bolt is supposed to be moving or not, but the whole pulley is supposed to turn. My pulley just stopped...got jammed, or bearings finally broke..so its making that typical scrreeching belt sound....
Old Dec 9, 2001 | 01:02 PM
turborotarypower's Avatar
on my car i get a groan on decelleration. i believe the air pump broke some kind of baffle in my airbox because i heard something pop,opened my airbox for filter change and this plastic piece that connects to the upper part of the box was laying in there!don't use it anyway because i gutted my cat.
Old Dec 9, 2001 | 03:38 PM
manatecu's Avatar
I have on sitting on my shelve collecting dust. I took it off at 30K if anyone is interest in it let me know.
Chris
Cstrain@coxnc.rr.com
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
