Need help on improving cornering ability
Old Dec 8, 2001 | 03:35 AM
Daw Tse's Avatar
I got a 90 vert, and handling is ok, not too bad, too much body roll...thinking of getting front and rear sway bars and a strut tower bar.
Any other suggestions? Which mods give you the best bang for your buck?
Old Dec 9, 2001 | 11:46 AM
turboren's Avatar
Suspension is always the best cheap upgrade you can make on a Vert, besides exhaust and an intake.
For about $1500 in mods, you can be pulling about .90 g's. For that kind of money, you can get performance springs and shocks all around (stock type, not adjustable coilovers), front and rear sway bars, front ant rear strut tower bars (although I think the verts come with a rear already), a and a complete set of suspension bushings, and maybe have enough left over to get them installed. Add in another $1500 for some good wheels and tires, and you'll be able to get close to 1.0 g. Another grand for some coilovers and DTSS elimination, and you should be at or slightly over 1.0 g.
These prices are for all new parts. You can get some used stuff in decent shape if you shop around.
Of course, you are already at somewhat of a disadvantage as compared to a hardtop, due to the lack of the structural integrity that roof would have provided.
Ren
Old Dec 9, 2001 | 01:45 PM
Cwaters's Avatar
Just Messing About
new struts!
you'll be shocked!
Cory
needs new front-side struts...
Old Dec 9, 2001 | 01:57 PM
Scott 89t2's Avatar
SOLD THE RX-7!
you can pick up set of kyb agx shocks from www.k2rd.com for $355. best shock for the money. and add a set of eibach or ST springs. eibach is a softer ride.
sway bars will help get rid of the body lean too. a strut bar will help cornering a bit. don't know if you can get a rear one for a vert.
most important thing is a good set of tires.
Old Dec 9, 2001 | 03:04 PM
topless7's Avatar
definately go with some springs and struts...it's amazing the difference it will make.
I also have the swaybars and a struttower brace. VERY solid ride. Oh, if you don't have 17" wheels that will also make a big difference in the handleing...
Snook
Oct 8, 2015 10:09 PM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
Ernstudet22
Sep 14, 2015 09:19 PM
