Throttle open angel
Old Dec 4, 2004 | 03:18 PM
DiabSoule's Avatar
Throttle open angel
Well iv been endeavoring to fix this idle problem for some time now. Iv read allot of post and posted allot myself. I cant seem to find this answer in the book or the forum if anyone has the answer it would be awesome.... What is the primary throttle angle at idle. i know that the secondary it supposed to start opening at 15 degrees of primary and then open in unison with the primary. i thought i had read somewere that it was like .043-.060 . again anyhelp would be great. i really really want to get her back on the street before it gets to cold and im forced to drive the mini van to work LOL... Thanks again
Old Dec 5, 2004 | 08:43 AM
Bob Holton's Avatar
recycled teenager
You got angels? .spell check strikes again. hehehe
Old Dec 5, 2004 | 08:51 AM
RotorMotorDriver's Avatar
Seven Is Coming
He mustve enslaved that darn guardian angel to open his throttle for him
~T.J.
EDIT: All right all right, in all seriousness, thats a question for someone like RX7Carl or Sterling. Try and PM one of them if no one responds here.
Old Dec 5, 2004 | 05:15 PM
DiabSoule's Avatar
I think a read check should strike again
[B]"What is the primary throttle angle at idle?"
ANGLE:35 entries found for angle. The first 10 are listed below.
To select an entry, click on it. For more results, click here.
angle[1,noun]angle[2,verb]angle[3,intransitive verb]Anglealternate angleangle bracketangle ironangle of attackangle of depressionangle of elevation
Main Entry: 1an·gle
Pronunciation: 'a[ng]-g&l
Function: noun
Etymology: Middle English, from Middle French, from Latin angulus
1 : a corner whether constituting a projecting part or a partially enclosed space <they sheltered in an angle of the building>
2 a : the figure formed by two lines extending from the same point; also : DIHEDRAL ANGLE b : a measure of an angle or of the amount of turning necessary to bring one line or plane into coincidence with or parallel to another
3 a : the precise viewpoint from which something is observed or considered; also : the aspect seen from such an angle b (1) : a special approach, point of attack, or technique for accomplishing an objective (2) : an often improper or illicit method of obtaining advantage <he always had an angle to beat the other fellow>
4 : a sharply divergent course <the road went off at an angle>
5 : a position to the side of an opponent in football from which a player may block his opponent more effectively or without penalty -- usually used in the phrases get an angle or have an angle....
in all seriousness i have PM'd Carl i will try sterling tonight while at work.. thnaks again for your time. I do hope someone knows the answer. My throttle body is screwed up bad allong with other items but i have to start somewere
Old Dec 5, 2004 | 05:33 PM
gsl-se addict's Avatar
Super Moderator
For the GSL-SE the published clearance on the primary plate is 1.1-1.7 mm (0.043 - 0.067 in). For the Nikki, it looks like the clearance should be 1.0-1.2 mm (0.040 - 0.047 in). This is from the FSM, BTW.
Hope this helps.
Kent
Old Dec 5, 2004 | 05:48 PM
Seven Is Coming
Main Entry: 1an·gle
Function: noun
Hey now, calm down, we were just messing around. Re-read the thread title now... Its all in good humor man
~T.J.
Old Dec 5, 2004 | 06:16 PM
Jeff20B's Avatar
Lapping = Fapping
You need an archangel, you know, because the angle has an arch in it (or a curve at least).
Old Dec 6, 2004 | 01:23 AM
DiabSoule's Avatar
Hey addict what page is that on.. are those measurements good from the 85 Gsl-se
I know ya'll are playing around. Hey thanks for all the advice.
Old Dec 6, 2004 | 12:49 PM
Super Moderator
For the GSL-SE, the measurement is listed on page 4B-46 of the 1985 FSM. I haven't measured mine, but I am sure if you get anywhere in that range (0.043-0.067 in), you should be fine.
Kent
Old Dec 6, 2004 | 08:21 PM
Bob Holton's Avatar
recycled teenager
Thank you, angleangel
Old Dec 8, 2004 | 12:46 AM
DiabSoule's Avatar
Thanks Kent i did go back and refer to the FSM. I Guess that page was missing ....LOL no i really over looked it thanks to you and our fellow ANGLE ANGEL's for setting me straight. Hopefully i can get her running this weekend.. I have a bad feeling that im looking at an E.C.U. prob though.
Old Dec 8, 2004 | 12:52 AM
Super Moderator
No problem. It is really hidden in there. It took me a bit to find it as well. Good luck with it. Let us know how it goes.
Kent
Shainiac
Jul 17, 2019 02:20 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Steelwheelz
Sep 15, 2015 03:22 PM
doritoloco
Sep 5, 2015 12:41 PM
