Too Cheap For Dyno....
Old Dec 6, 2001 | 08:22 PM
Turblown's Avatar
Turn up the boost
Arrow Too Cheap For Dyno....
Can anyone tell me how much hp i have with these mods?
88'GTU
Dual Underdrive Pulley for Alternator
Main Eccentric Shaft Underdrive Pulley
Bonez Cone Intake w/ Fresh Air Headlight Cover & Cold Air Box
Ripped out a/c, ac/cv, egr, airpump
Midpipe ( no cats )
FreeFlow Mufflers
Cleaned Fuel Injectors
& how much more if i had my stock intake bored out & possibly polished.
Old Dec 6, 2001 | 08:46 PM
Scott 89t2's Avatar
SOLD THE RX-7!
probably not too much. if you're cheap just find someone who owns a G-tech
Old Dec 6, 2001 | 09:22 PM
banzaitoyota's Avatar
What Subscription?
on the honda meter 372.658914
no way to know your real numbers unless you dyno'd b4 and after mimicing atmospheric conditions the best u can.
Your money would probably have been better so\pent by performing a proper compression test followed by a through tune-up if the motor was in decent shape.
If the motor was in degraded condition just but the money in the bank to save for a rebuild.
Old Dec 6, 2001 | 09:25 PM
KNONFS's Avatar
B O R I C U A
If you motor has good compression, 120-130HP sounds about right.
Old Dec 6, 2001 | 09:35 PM
dre_2ooo's Avatar
Re: Too Cheap For Dyno....
88'GTU
Midpipe ( no cats )
FreeFlow Mufflers
WOW! another minnesota RX-7 SWEEEETT!!
well let's see, your car has 146hp STOCK, so i'd say around 160-170ish... plus your wieght reductions.. probably put you in the mid 15's too. (your car is like 16.3 stock)
The 89-91's had 160hp Stock...hehe
Old Dec 6, 2001 | 10:04 PM
Turblown's Avatar
Turn up the boost
I have done seriously ever tune up and maintence possible..
But i haven't had time to do a compression test. What is a good range for my compression to be in? I was thinking about getting a rebuild done too, that or a new block. What would be better a total rebuild, with everthing replaced, or a new block? I was also thinking about dropping in one of those cheap J-spec engines, of course with a turbo or maybe just a rebuilt/new turbo II block. all i would need is a haltech and a bigger fuel pump, i already got the TII drivetrain Does anyone else have any suggestions?
Old Jan 11, 2002 | 08:14 PM
NOTA V6's Avatar
Dre2000 and 1Revvin7: Join the club ($25 per year), and come join us on our next Dyno outing. We get group discounts for going together. It's usually around $40-$45 for 2 runs.
And if you are even more umm... frugal than that, I have a G-Tech. We need a strip longer than a 1/4 mile on level ground to use it though. Any ideas?
Take care,
Old Jan 11, 2002 | 08:19 PM
NOTA V6's Avatar
A new engine is better than a rebuild. A J-spec is a cheap solution. I imported a TII fron end form Australia, and got the motor, tranny, and all kinds of spare parts. After selling my current stuff (even a blown motor is worth something) I should come fairly close to breaking even. I plan on using a Wolf 3D V4 to run it.
Another god reason to join the club? We are buying a compression tester as we speak.
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
Captain Hook
Sep 22, 2015 01:12 PM
Xepez
2nd Generation Non-Technical and pictures
Sep 22, 2015 03:15 AM
