To run Nos or Not to run Nos
Old Dec 6, 2001 | 05:21 PM
Flinstone Power
Question To run Nos or Not to run Nos
I have a 87 GXL with 181,378 mile but has good compression. I was wondering if I can run NOS and what kind of kit how big of a shot, install time tools needed,(can I do it myself). The mods on the car already are HKS cold air intake, 550cc sec injectors, header with 3in collector, 3in mandual bent exhaust with 3inch cat to y pipe, 2.5in y pipe into 2.5in dyno max bullet race mufflers.
Thanks for the help dave
Old Dec 6, 2001 | 06:03 PM
RETed's Avatar
50-shot is about as big as I would go.
Your exhaust is way too big for everyday NA driving - you're losing a lot of low end torque due to the overly large exhaust piping.
-Ted
Old Dec 6, 2001 | 06:37 PM
I agree with reted. You could do a 100 shot of NOS if you got more fuel into the motor. Probably use a wet Nos system and an additional fuel pump.
Old Dec 6, 2001 | 06:57 PM
live4boost's Avatar
AKA ShepFC3
stick with 50 if any. Yes you can install it yourself if you are decent with tools. There are two different systems, wet and dry. I won't go into detail, but you should find out what would be better for your needs. fc3s.org has an installation write-up on a nos kit if I remember correctly.
Old Dec 6, 2001 | 07:03 PM
PlayinW/Wankel's Avatar
what are the dangers of using a 50-shot on a stock engine, with 107,000 miles and good compression? Can my stock drivetrain handle the extra power if I only use it above 4000 rpms? I would probably only use it every once in a while, but I dont want my engine to die if I only use it a few times. It seems like a realitively inexpensive way to boost hp, but if it will kill my engine it is not worth it.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
The Shaolin
Sep 14, 2015 07:50 PM
