Gauges & sensors and stuff
Old Dec 5, 2001 | 08:55 PM
Barwick's Avatar
SCCA Rookie
Ok, I don't know the first thing about gauges and all them gadgets, and hooking them up. I've never needed them (all regular street cars) But now I've got to get a couple for my Race car, and another couple for my '79 getting a 13bt.
I'm going to be needing an Exhaust Gas Temp gauge that can handle 1700 degrees Farenheit (normal temperature), most only read up to 1600 max.
I'll need oil/water temp gauge(s)
Oil pressure gauge(s)
Boost Gauge
Air/Fuel ratio gauge(s)
What else should I be looking for?
Also, when I buy the "gauge" does it come with the appropriate sensors (water temp sensor and what not for the water temp gauge?)
Old Dec 6, 2001 | 01:02 AM
surfpac's Avatar
EGT
You can get an EGT gauge, sending unit (probe) and light kit for around $70-80 from Aircraftspruce.com. They sell all types but this one has a range of 0-1700F and is made by Westach. It is very reliable, accurate and lightweight and typically are used in small aircrafts but works fine for our cars.
AIR/FUEL
There are all types of air/fuel mixture gauges out there that are pretty good Autometer, Halmeter, etc. I custom make these with various sizes and color LED's including a dot/bar mode and brightness switch.
BOOST
These range from around $10 to over a hundred. Yes, $10 from any industrial supply company but you'd have to custom install it. Or you can get the typical ones you see in many cars that mounts into an A pillar pod.
All these including the weter temp, fuel pressure, oil pressure are equally as important.
Old Dec 6, 2001 | 09:44 AM
Barwick's Avatar
SCCA Rookie
$70-$80 for the EGT is a lot better than the $220 I've been seeing everywhere. Now I need to find a way to find exactly what I need, and tell my parents cause they want a Christmas list for me, might as well put it to good use, rather than them getting clothes I'll never wear.. when I start getting naked from worn out clothes, then I go buy some more.
Old Dec 6, 2001 | 01:17 PM
surfpac's Avatar
http://www.frostalarm.com/cat/p2.html
Old Dec 6, 2001 | 03:13 PM
Barwick's Avatar
SCCA Rookie
wow.. that place is awesome.. everything I need, and more! :p
Old Dec 7, 2001 | 04:34 PM
13BAce's Avatar
On a long vacation
Originally posted by surfpac
EGT
Thanks for the tip. I'll check it out. I need something to replace my Greddy gauge because it stopped working.
Old Dec 9, 2001 | 07:25 PM
surfpac's Avatar
You can get Westach to custom make them too in different temeperature ranges C or F and different colors to represent certain ranges.
streetlegal?
Mar 17, 2022 02:46 PM
Snoopy FD
Dec 8, 2015 01:45 PM
