Wideband placement on RB exhaust?
Old Nov 16, 2004 | 12:17 AM
Net Seven's Avatar
Hey guys I have a full turbo back racing beat exhaust system. I just recently ordered the LM1 wideband and was just wondering what would be a good place to put the o2. I was reading how the heat can really mess up the sensors and that it needs to be placed before the cat, but since I dont have a cat... is anything affected if I place it after the pre-silencer so its farther away from the heat. This sensor will stay on the car all the time as it will be used by my wolf3d for closed loop.
I was thinking about placing the sensor right at the point on the y-pipe where it starts to Y off and go into 2 pipes.
Old Nov 16, 2004 | 12:38 AM
I wish I was driving!
If you're worried about heat, put it right before the silencer: it will be fine there for sure.
Old Nov 16, 2004 | 12:47 AM
Net Seven's Avatar
I just measured and thats about 35 inches down from the turbo. Should be fine there huh?
Old Nov 16, 2004 | 12:52 AM
Definitely.
Personally, I use an FJO unit and put it within 4 inches of the turbo. No problems with snesor life/output yet.
Old Nov 16, 2004 | 06:37 AM
KNONFS's Avatar
B O R I C U A
Mine is on the DP, 6 inches before the MP, 6 months now without a single problem
Old Nov 16, 2004 | 10:06 AM
Net Seven's Avatar
what kind of wideband are you using?
Old Nov 16, 2004 | 12:56 PM
KNONFS's Avatar
B O R I C U A
http://www.plxdevices.com/
Old Nov 23, 2004 | 12:22 AM
mr_vaughn's Avatar
Chillin
i got a heat sink for my LM-1 which i will try and use the stock locationand i will also be installing an EGT just mear it about 1 - 2 inches up from the O2 sensor.
doritoloco
Sep 5, 2015 12:41 PM
