RX-8 RENESIS Apex Seals @ 13b-REW
Old Nov 11, 2004 | 02:57 PM
AImec Racing's Avatar
so ...no time for this
Exclamation RX-8 RENESIS Apex Seals @ 13b-REW
I posted this at the RA thread but decided to post it here to keep it separately:
"BTW, there are two other friends I know that are currently using RX-8 seals. They are a 2-piece thinner design with longer springs. One of them is a racing drag car that I personally saw it dynoing 647 whp with a lot more than 10 passes. They have not blew/chk them yet but have not reported any problems. The other one tried them in an FD and blown them while tuning the car. So it looks to me like is a good seal if the ECU is WELL programmed/tuned. I will probably go with the RX-8s next if something goes wrong with the RAs. I will let you informed about my car (FD3S) and everything else."
Has anyone tried the RX-8s?
Old Nov 11, 2004 | 05:07 PM
drago86's Avatar
bad idea with PP exhaust.
Old Nov 20, 2004 | 05:48 PM
What do you mean? Have heard any bad experience?
Old Nov 20, 2004 | 06:07 PM
nonameo's Avatar
**-P I drive a miata.
I think what he is trying to say is that the thinner apex seals will arc a little and hit the lip of the exhaust p-port. This isn't a problem with the renesis because the exhaust ports are on the side.
Old Nov 20, 2004 | 06:24 PM
rotarygod's Avatar
Rotors still spinning
Actually yes, this has been proven. Mazdatrix found this to be true. They bend when crossing the peripheral exhaust port.
Old Nov 25, 2004 | 10:09 PM
kevinvr6's Avatar
Gremlin Hunter
so no good?
Old Nov 26, 2004 | 03:40 AM
RETed's Avatar
I wouldn't trust information unless I have personally seen the seals go in.
-Ted
Old Nov 27, 2004 | 03:53 PM
t-von's Avatar
Rotor Head Extreme
Also aren't the Rx8 seals like thinner than the normal 2mm seal? If so they would have too much side clearance.
Snook
Oct 8, 2015 10:09 PM
