HELP! Car won't start!
Old Nov 7, 2004 | 01:49 AM
kale717's Avatar
I noticed a month ago my car was becoming more and more difficult to start, and now it won't start at all. I clutch in and turn the key to the start position but the engine doesn't turn.
Facts:
I have power - and it's not the battery because I hooked up a new optima and got the same results.
I don't hear the starter, and of course don't hear any plugs firing.
While holding the key in the start position my air/fuel ratio moves from lean to balanced when I clutch in (which is normal).
My clutch plate is EXTREMELY worn down (I'm in the process of replacing it now)
Soooo would a worn down clutch plate keep my car from starting? Loose wire? Bad starter solenoid?
Any help would be appreciated!
Old Nov 7, 2004 | 01:57 AM
FDeez's Avatar
Could be the clutch pressure switch. It's a button behind your clutch pedal near the top. Perhaps that needs adjustment. If not, you might need a new one.
Old Nov 7, 2004 | 02:05 AM
vel525's Avatar
Woo Hoo, It Runs!!
maybe a starter?
does it turn over at all?
Old Nov 7, 2004 | 02:13 AM
kale717's Avatar
No it doesn't turn over at all.
I don't really know anything about them - but don't starters usually start sounding weird and stuff when they are going bad - in my case I don't even hear the starter running, like it isn't getting power or something.
I dunno!!
Old Nov 7, 2004 | 02:16 AM
littlemilla3's Avatar
Possibly the starter. Get a broomstick and give it a little jab and see if that helps any.
Old Nov 7, 2004 | 01:31 PM
kale717's Avatar
broomstick eh?
Old Nov 7, 2004 | 01:35 PM
derty's Avatar
yes, get underneath your car and give your starter a hit with something. Then see if it starts up if it does it means your starter is going.
Old Nov 13, 2004 | 02:19 PM
93FD3S's Avatar
Big Snail
I'm having the same identical problem....!! Anyone have any ideas?
Old Nov 13, 2004 | 10:25 PM
Csefiroth0's Avatar
it's the starter... i know it sounds like primitive ****.. but seriously get under there with a hammer and whack the starter a few times... it will run
Old Nov 13, 2004 | 11:35 PM
RX7UP's Avatar
BOYCOTT EXXON MOBIL!!!
I know...... Get some gas and a match...... Then it will start! ....... lol (Just Kidding)
alphawolff
Nov 17, 2015 05:57 PM
