Does anyone know what this is?
Old Nov 3, 2004 | 05:57 PM
duo_z's Avatar
Newbie
I need to know what this is as you can see its broken so in need a new one. The dealer doesnt know either but he said he could probubly get it if i figure out what it is or does. it was connected down by the tranny
Old Nov 3, 2004 | 05:59 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
It is the resistor that goes on the engine block IIRC. I forgot its purpose but they shouldn't be expensive.
Old Nov 3, 2004 | 06:08 PM
Kenteth's Avatar
Like Ghandi with a gun
capacitor for the oil pressure gauge and censor. It gets connected to the red/yellow wire that runs parralell with the oil pressure sensor and guage. It keeps spikes from kicking the **** out of the gauge.
Old Nov 3, 2004 | 06:41 PM
DerangedHermit's Avatar
Isn't it the ground that goes on the slave cylinder (or was it between the starter and tranny)?
Old Nov 3, 2004 | 06:42 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Yes. I didnt know it was related to the oil pressure gauge.
Old Nov 3, 2004 | 06:53 PM
DAN CARWIN's Avatar
I believe the Mazda dealer told me it was a radio resistor or some useless bull ****. It has NOTHING to do with the oil preasure gauge.
Old Nov 3, 2004 | 06:57 PM
Rxmfn7's Avatar
Do a barrel roll!
Quit listening to the mazda dealership....
Old Nov 3, 2004 | 07:03 PM
I wish I was driving!
You're gullible.
Why would Mazda put a radio resistor in the engine bay?
Old Nov 3, 2004 | 07:09 PM
Odd, then, that its in the FSM's wiring diagram... (the red circled item)
Old Nov 3, 2004 | 07:10 PM
If I could read that, I'd tell ya .
Old Nov 3, 2004 | 07:20 PM
It says condensor.
What size monitor do you have? 11" black and white? It reads clear as day on mine(19" LCD)
Old Nov 3, 2004 | 10:05 PM
Kenteth's Avatar
stfu noob.
EDIT: and one of the first things you should have learned was the dealer knows about as much about the rx-7 as my cat knows about rebuilding a rotary.
EDIT2: I take that back, I'm pretty confident my cat can at least identify a rotary engine, mazda dealers can't even do that without a ******* computer to tell them.
Old Nov 3, 2004 | 10:10 PM
hypothermix79's Avatar
I had one of the bolted to the starter bolt when i changed my starter. didn't know what it was though it was broken too. my oil pres gauge didn't work any ways so I bought an after market one.
Old Nov 3, 2004 | 10:35 PM
patman's Avatar
Resident Know-it-All
certainly doesnt have any major effect on the oil pressure guage... ive run cars with/ without it hooked up or even on there with no noticable difference in anything. if you really want one, i'll send it to ya for $2 to pay my shipping costs.
pat
Old Nov 3, 2004 | 11:57 PM
Originally Posted by Kenteth
capacitor for the oil pressure gauge and censor. It gets connected to the red/yellow wire that runs parralell with the oil pressure sensor and guage. It keeps spikes from kicking the **** out of the gauge .
Old Nov 4, 2004 | 12:03 AM
It says condensor.
I was referring to my lack of knowledge in the electronics department.
BlackRx7's Avatar
Daily Domestic Killer
Ha that is so true the wire connecting to my condeser just broke and I noticed it spiking out of no where. luckily i had an after-market oil pressure gauge to confirm that my oil pressure was fine and the guage was just flipping out
Old Nov 4, 2004 | 12:07 AM
Kenteth's Avatar
pat
This is true, its just a safety precaussion so that the $20 dollar sensor doesn't kill the $10 gauge (smart mazda eh?) The guage will run 100% fine with it so long as the sensor doesn't try to kill them both. Coincidentaly, the actual capacitor for replacement would cost about $.75 at radioshack. Otherwise I ave my sensor wired straight to the gauge without the parraelell capacitor.
Old Nov 4, 2004 | 12:13 AM
So the "condensor" helps save the gauge or the sender? Just want to make sure. My wire broke off and I'm using an aftermarker oil pressure gauge anyway. Just wanted to know if this is what is stopping my stock gauge from working. If the gauge itself is screwed now what options are there to fix it? I know the sender can be replaced easily.
Old Nov 4, 2004 | 12:22 AM
Gauge.
It smooths out the signal from the stock sensor.
Old Nov 4, 2004 | 12:27 AM
so basically if the gauge is shocked because the "condensor" isnt working correctly then the gauge is FUBAR'D permanently?
Old Nov 4, 2004 | 01:29 AM
Kenteth's Avatar
Technicaly... it is keeps the driver from not freaking out when he/she sees the oil pressure change rapidly. With the condensor, it would smooth it out....
Anyhow, technicaly you can run without it, I have and have had no problems. If it breaks at some point, I'll buy a cheap $20 senger/gauge unit that probably works twice as good as the stock one anyhow...
Old Nov 4, 2004 | 12:37 PM
I spent about $200 on my electric blitz pressure gauge. Just wanted to see if I could get my stock gauge working again to compare accuracy between them.
Old Nov 4, 2004 | 03:33 PM
Kenteth's Avatar
and the comparison on them?
Old Nov 4, 2004 | 05:16 PM
I couldnt say my stock one doesnt work and I think it's dead because the wire to the condensor on the slave is broken. I didnt bother replacing the stock sender to see if that was also malfunctioning. I trust my blitz one. It's installed with an aftermarket oil pedastal BTW.
