street port na power output not right.
Old Nov 2, 2004 | 12:22 PM
atlbaseball877's Avatar
I have an 87 na street ported motor with intake and full exhust yet the power out put to the rear wheels is less than stock.
124rwhp
119tq
power output should be more than that i would think. whats the deal here. need ideas on whats wrong.
Old Nov 2, 2004 | 12:31 PM
RXciting's Avatar
GrapefruitRacing?
**** if it's streetported i think you should be seeing at least over 160 with those mods..
hav you done a compressio check??
Old Nov 2, 2004 | 12:38 PM
So close to 12's!!!
5/6th ports not opening correctly.
RXciting's Avatar
GrapefruitRacing?
yea could be that too... didn't cross my mind :S
Old Nov 2, 2004 | 01:11 PM
cwsttu's Avatar
1.3L is not that small
hope you did that to the motor youself or had somebody you trust do it.... otherwise if you bought it streetported it might have been a scam..... otherwise check the compression and your 5th and 6th ports.... does the car run well? timing set correctly? any hesitation
Old Nov 2, 2004 | 02:20 PM
koukifc3s's Avatar
Clogged cat
what yr, other mods?
Old Nov 2, 2004 | 02:32 PM
Kenteth's Avatar
Like Ghandi with a gun
thats terrible... whats the story on it?
EDIT: I was in whichita a few years ago, they were rebuilding the interstate/turnpike at the time.
They ever get it finished?
Old Nov 2, 2004 | 02:36 PM
DerangedHermit's Avatar
What kind of streetport? If it's just a small streetport those numbers could be *decent* depending on how many miles are on the engine.
I would guess either: a) you got screwed and it's not ported, b) your 5/6th ports aren't opening (does it have S4 intake manifolds or S5, with S5 the VDI might not be working), or c) your engine needs a compression check.
Old Nov 2, 2004 | 07:38 PM
RETed's Avatar
What did it do before?
6 ports not working?
Ignition timing not in spec?
Fuel injectors too big?
FUel pump too big?
-Ted
Old Nov 3, 2004 | 04:09 PM
The motor was rebuilt by atkins rotary and installed by a rotary mechnic here in town. the 5th and 6th are working as i can see them move when reving. One thing that i thought i could be is that I have a falty injector or all injector are drity or cloged. Because it idles rough and the highest i can get the idle to go is 900 rpms with the screw almost all the way out. maybe I just do have enough fuel period.
Old Nov 3, 2004 | 04:15 PM
also the motor sound like its runing lean with alot of back firing. When its cold it hesitates when the ports are supose to open but when it warms up everything seem to be fine
Old Nov 3, 2004 | 07:24 PM
RETed's Avatar
How much miles after the rebuild?
-Ted
Old Nov 3, 2004 | 07:35 PM
ronyrx7's Avatar
probobly not brken in did the injectors work b4. comp check then get back to us
Old Nov 3, 2004 | 08:19 PM
speeddemon32's Avatar
No more 7 or 8
could be not broken in yet....... but first, are you comparing your 124 wheel horspower to the 146 flywheel horse power stock?
If so then there is your problem. ....... (you dont have a problem.)
Old Nov 3, 2004 | 08:20 PM
No more 7 or 8
..... although i would still think you would be a little over 124 rwhp.... is this a N/A?
Old Nov 3, 2004 | 08:56 PM
1RevvinFC3S's Avatar
DOWNSTAIRS MIXUP
I would ASSUME its N/A because if a TII is making less than 130 at the wheels, I would say its only running on one rotor.
Old Nov 3, 2004 | 09:37 PM
SAiamNE's Avatar
If you have no clue what your talking about please don't post... No he is oviously not running on one rotor.. LOL
Old Nov 3, 2004 | 09:51 PM
rxspeed87's Avatar
lol red the whole thing
he was saying a tii making 130hp is prolly running on one rotor
not this guys' N/A is running on one rotor
Old Nov 3, 2004 | 11:40 PM
koukifc3s's Avatar
Clogged cat
if its not broken it why dyno it?
Old Nov 4, 2004 | 02:31 PM
It has a little over 15000 mile on the engine so it broken in. I just changed the spark plug and it helped but not alot. They looked like they needed to be anyways. I don't think the guy who installed my engine checked to see if the injector were ok. But as far as i know they are the orginals. Yes its a N/A. I'll do compression check later and update
Old Nov 4, 2004 | 03:29 PM
Update compression test done and results are 55 to 60psi in front chamber and 60 to 65 in rear all are consistent . Don't know weather this is good or bad. Answer pleases
Old Nov 4, 2004 | 04:16 PM
koukifc3s's Avatar
Clogged cat
Those are not good #s
"115+ is like new, 100-115 is healthy, 90-100 is getting weak(1 year or less in most cases) below 90 could blow at any moment."
http://www.rotaryresurrection.com/ro...lder/comp.html
Are you sure you did the comp check right?
Old Nov 4, 2004 | 04:52 PM
I did it with a normal compression checker(autozone) and followed the instrutions in the hanes book. The book tells me to use the top plug hole and the website you gave me tell me to use the bottom plug hole. I'll try the bottom plug holes tomorrow and check back with results.
Old Nov 4, 2004 | 07:13 PM
RETed's Avatar
Did you prop the throttle when doing the compression test?
Did you take out both trailing (top) spark plugs?
Did the battery have top charge?
http://fc3spro.com/TECH/FAQ/compress.html
-Ted
Old Nov 4, 2004 | 08:46 PM
ronyrx7's Avatar
if you folwd the instructions and got those numbers there is something wrong i have an autozone tester and my results are 120 on each rotor 15000 miles when did these problem start. there is no way you have been driving that car for so long in that condition.
