Videos of my 12a bridgeport turbo 1st gen
Old Oct 25, 2004 | 05:35 AM
12at's Avatar
10.21 @ 137mph
Here are a few videos of my car. I friend was kind enough to host them for me so I thought I would post them in here.
A 1/4 mile run- http://www.rxfelix.com/boosted712at.mpg
Some tyre smoking fun- http://www.rxfelix.com/springnatsdonuts.wmv
Idling - http://www.rxfelix.com/bridgieidle.AVI
ENJOY!!!
Old Oct 25, 2004 | 12:47 PM
pillage6's Avatar
Any specs on the turbo and intake?
I am going to do a 12A bridge, 48 DCO with a blow through T4/T76 soon and wanted some suggestions.
Damn nice car, thanks for the vids!!
Old Oct 25, 2004 | 04:23 PM
680RWHP12A's Avatar
nice run!! whats your 60 foot time?
Old Oct 26, 2004 | 03:16 AM
12at's Avatar
10.21 @ 137mph
Smile
Im using a TA45 turbo and the intake is a 13b turbo one with an adaptor plate on it.
680RWHP- The 60' footer was 1.63. There is still some more left in it.
Old Oct 26, 2004 | 10:17 AM
Supper's Avatar
Darth Suppah
Damn. Thats just bad ***.
That thing idling sounds like my snowmobile with headers and reed valves
I love it. Hopefully mine will sound that way soon as well. What kind of exhaust setup you running?
Old Oct 26, 2004 | 06:09 PM
setzep's Avatar
What rear axle do you have in that beast?
Old Oct 27, 2004 | 03:37 AM
12at's Avatar
10.21 @ 137mph
It has a 3.5 inch dump pipe then it goes down to a 3 inch system with 2 straight through mufflers.
The rear end is a shortened hilux differential. I dont know if you got Toyota Hilux's over there. They are a small 4 wheel drive. They are becoming a common conversion over here as they are quite strong and have very big 30 spline axles.
Old Oct 27, 2004 | 06:43 PM
setzep's Avatar
It might be the same or similar to a standard Tacoma or toyota pu rear.
I just watched your video again.... MAN what rpm do you launch at?? sounds to be at least 8k?
Old Oct 27, 2004 | 11:06 PM
REVHED's Avatar
Hunting Skylines
AJC-13B was launching at over 10k I remember correctly.
Old Oct 28, 2004 | 01:41 AM
12at's Avatar
10.21 @ 137mph
Because of the tall rear tyres and 4.3 diff gears I revved it to 11k off the line. Next time out it will have 4.8 diff gears so I dont have to wring its neck so much.
Old Oct 28, 2004 | 05:43 PM
setzep's Avatar
Jesus! And I feel bad setting my rev limit to 8300... BUT I only have a stock port 13b-re
Old Oct 28, 2004 | 05:53 PM
Parastie's Avatar
Mountain Rotary Mod
Man that is awesome! Thanks for the vids!
Old Oct 31, 2004 | 11:06 AM
wickedrx2's Avatar
what kind of timming r u running,what kind of spark plugs and what size of gap on them, im trying to tune a cosmo block with semi pp ports running a t72 turbo with a locked distributor
thanks for your help
Old Oct 31, 2004 | 11:33 AM
pillage6's Avatar
The aussies have all the fun
Hopefully within 2 months I will have a blow through bridgeport to video
Old Oct 31, 2004 | 09:35 PM
hiboost7's Avatar
nice run. hey SUPPER, i know the chick in your avatar
Old Nov 4, 2004 | 04:41 PM
Fd3BOOST's Avatar
Recovering Milkaholic
What are you doing for EMS? Nice times. I'm impressed. Lastly is it a full bridge or half?
Old Nov 4, 2004 | 11:25 PM
What kind of tranny r u running?
Old Nov 4, 2004 | 11:27 PM
what kind of tranny r u running?
Old Nov 5, 2004 | 12:19 AM
12at's Avatar
10.21 @ 137mph
I am using a Microtech LTX8 ecu and the tranny is a Guru dog box. It is a full bridgeport too.
Old Nov 5, 2004 | 08:49 AM
Is it clutchless dog box? How much for it?
Old Nov 5, 2004 | 08:32 PM
12at's Avatar
10.21 @ 137mph
Info on the tranny's can be found here....http://www.gurumotorsports.com/
They are $8900 australian dollars. And yes you can change clutchless. It is awesome to use.
Old Nov 8, 2004 | 01:26 AM
Did u run with LSD for your current Hilux 4.3 rear end?
Old Nov 9, 2004 | 02:25 AM
12at's Avatar
10.21 @ 137mph
No I just welded the spider gears on the diff, It is locked. You cannot buy a full spool for these diffs yet.
Old Nov 9, 2004 | 07:43 AM
Welded the spider gears but it hard to drive. R u looking lock-right lockers for your Hilux diffs? Its 30 spline. Visit this site www.summitracing.com
Click online store select ( drivetrain) click again (Differential & Rear-End, Components & Accessories) and then select (Powertrax Lock-Right Lockers).
May i know did u dyno test your series 3 Rx7?
Old Nov 10, 2004 | 01:50 AM
12at's Avatar
10.21 @ 137mph
I only welded the gears because it is cheap and the lsd's dont last. Guru Motorsports are developing a torsen lsd for the hilux diff's like the ones they make for the mazda diffs. Once that is released I will get one of those.
Yes I dynoed my car, it made 480rwhp.
