Oil Disaster - Aftermath
Old Dec 1, 2001 | 01:51 PM
SilverZ's Avatar
Looks like it was just my oil filter... which sounds like an obvious first thing to check out, which is really what I did; I was just worried that it might be related to something else that would blow my oil filter seal off. So I changed the oil filter... and now this is how my oil pressure is acting.
On the stock scale of 0-8(unsure of units kPa??)
Warmup: 7
b/w 0-3000 rpm: linear increase in pressure
3000 rpm: 4
@ idle, 800rpm, it is almost at 0??????
Is this right? Im worried that maybe there was something else that went wrong that cause the oil filter to blow in the first place.
Thanks for any help.
Old Dec 2, 2001 | 01:15 PM
dis1's Avatar
www.silverbulletrx7.com
Your numbers sound about right. What type of filters are you using? Hopefully not crap like Fram or something. Also if you over tighten the filter is can cause the seal to go bad. You should also coat the seal with fresh oil before putting it on so it doesn't grip the face and tear. Just some pointers just in case.
Old Dec 2, 2001 | 04:43 PM
SilverZ's Avatar
Thanks alot..... so the oil pressure should stay close to zero at idle, no throttle.
Thanks for the help guys... save me a ton of cash getting it looked at by Mazda.
Old Dec 2, 2001 | 06:44 PM
dis1's Avatar
Yea, most people see oil pressure around zero at idle. If you see strange oil pressures associated with the oil pressure gauge needle jumping around a lot it's probably the sensor. They fail pretty often.
cvs
Old Dec 3, 2001 | 10:15 AM
maxpesce's Avatar
Ex fd *****
I think the metric Oil Press guages are marked in Bars (1 bar = aprox 14.2psi) Though Bar and Kpa are almost equal. , I never see less the 30psi (2+ Bar) at Idle on my freshly rebuilt motor and even just prior to the rebuild I had at least 20 psi at idle. I think if you are seeing less than 1 Bar or Kpa at idle you may have a problem.
Old Dec 3, 2001 | 04:11 PM
SilverZ's Avatar
I am having rough start ups now... It cranks a bit before it actually fires.....Can this be related?
Could this hint to what might of blew the seal out of my oil filter?
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
