Really bad drivability, need help.
Old Oct 15, 2004 | 05:27 PM
V8what?!'s Avatar
bov ftw
Question Really bad drivability, need help.
I have a TII which won't idle and bucks/stutters super hard over 30% throttle. I've timed the car, checked the main ground, replaced the battery, changed the spark plugs, changed the tps twice, changed plug wires, and changed the fuel filter...I'm checking the injectors next...any other ideas?
Old Oct 15, 2004 | 05:33 PM
S13 Slide's Avatar
i had a fcd that got dipped in water and did the same things yours is doing. checked/replaced everything without knowing it was the fcd. i pluged the sensor i normal and my car was drivable again. just a thought.
Old Oct 15, 2004 | 06:07 PM
amishboy's Avatar
90 Turbo
I think the injectors will get it probably the secondaries with the over thirty percent thing
Old Oct 17, 2004 | 06:43 PM
V8what?!'s Avatar
bov ftw
Thanks for the replies. I'll check that fcd out.
Old Oct 17, 2004 | 07:04 PM
pr0digy's Avatar
My car's doing exactly the same thing, except it smooths out at WOT, and mine is a streetported NA which I've been driving for over 5 months now. DIdn't use to do this, and I still have no idea what it could be, replaced pretty much everything that V8What did, but to no avail. ANy ideas?
Old Oct 18, 2004 | 02:32 AM
V8what?!'s Avatar
bov ftw
Yes. Anything would be great to hear...
Old Oct 19, 2004 | 12:49 PM
V8what?!'s Avatar
bov ftw
Well, I hoped it would be as easy as the fcd, but it sure isn't. Still don't know what the problem is either...doesn't want to idle either. Do you have that problem too, pr0digy?
Old Oct 19, 2004 | 01:35 PM
SureShot's Avatar
Seduced by the DARK SIDE
Clip an Ohmeter on the AFM & work the plunger - the resistor may be worn/dirty/sticking.
Old Oct 20, 2004 | 07:11 PM
V8what?!'s Avatar
bov ftw
What should the AFM read?
Old Oct 20, 2004 | 07:34 PM
WAYNE88N/A's Avatar
About 4v key on, about 3v at idle, and she'll fall towards about .5v during the hard runs...
You need to read a couple of thing out at the ECU while driving (you guys with the problems), including TPS, AFM, water thermo sensor, the two temp sensors, and the boost sensor...
Old Oct 21, 2004 | 03:00 PM
V8what?!'s Avatar
bov ftw
So you're saying that I measure these from the ecu while driving, eh? Should I just find where they plug in to the ecu and stick the meter's prongs next to them?
rx7nepal
Jun 8, 2022 10:04 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
R.O.D
34
Jan 6, 2016 12:09 AM
