Does anyone run a PTE T71-GTQ?
Old Oct 12, 2004 | 12:38 PM
respecthewankel's Avatar
I drive on the right side
I'm running a gotham racing half bridge, and an AEM EMS, along with a methanol injection kit. A local guy is selling a Precision T71-GTQ for sale, with a tangential .96 A/R undivided exhaust housing. It is new in the box, the price is amazing, but will this turbo be a good fit for my car? Being a half bridge and going to a large turbo it's obviously not my daily driver anymore, but I do intend to drive it lots on the weekends and maybe once a week to work if the weathers nice, so I don't want to have some huge lagmaster turbo. Is anyone here using this? When does it start to make boost? How's the efficiency at low boost levels?
Old Oct 12, 2004 | 02:38 PM
modrx7's Avatar
Sounds like a match made in heaven... you might want to get a divided housing though, because it will help the spool
Old Oct 12, 2004 | 04:00 PM
dvls-7's Avatar
Sick & Twisted
ditto...
You'll like that turbo. Im also planning on getting a Precision unit those guys really know their stuff.
Old Oct 12, 2004 | 04:35 PM
Crusader_9x's Avatar
its only goona help spool if you have good divided equal length manifold to g with it.
Old Oct 12, 2004 | 05:54 PM
My issue, does anyone even make a divided turbine housing for a GT-Q trim exhaust wheel?
Old Oct 12, 2004 | 06:06 PM
modrx7's Avatar
isn't it just a t4 so why couldn't you have one made, or buy a hks one?
Old Oct 12, 2004 | 06:55 PM
Infini IV's Avatar
Microtech Tuning!
A lot of places can have any turbine housing machined to fit the GTQ wheel. You can also contact Precision, as they would probably have turbine housings in stock.
Old Oct 13, 2004 | 05:45 AM
Mike_REW's Avatar
Yes, the standard P-trim exhaust housing is machined out to accept the GTQ turbine wheel.
This additional labor justifies the additional cost of this setup versus the standard P trim stuff.
--Mike
Old Oct 14, 2004 | 10:36 PM
Rx_treme's Avatar
Carx7 had his backside milled out for the GTQ wheel b/c he needed it divided.. it ended up cost right around $700 including the cost of the backside (was a divided .84) he also had a ball bearing center section made tho too. he gets 19 psi by 3700ish on a street port.
I opted for the pt67 gtq .81 undivided and i get 19psi by about 5000 on my stock port RE.
Old Oct 15, 2004 | 11:47 PM
sub-zero's Avatar
I have heard from many People that runnning a un-divided housing on a divided mani works better then the divided housing? You will not notice nay difference.
Old Oct 16, 2004 | 12:42 PM
carx7's Avatar
Everything I have read from experienced people on this forum suggested divided/divided is the way to go. Precision only sells undivided housings as they claim it makes more power and doesn't help spool. I disagree, but really have no proof, so that's hard to argue. Also, when I talked to .... Harry I think... at Precision he did say that their expereince with more power from undivided is specifically related to piston motors, and we all know that rotaries behave very differently.
I wanted to do a dyno comparison with the two, but since I run a 4" DP it's kinda hard to justfity the cost of a undivided housing just to prove which one makes more power.
As for the spool of my turbo, I am very happy, and am convinced that the .84 housing and GTQ wheel are good for more than 500RWHP, so I don't see a reason to go bigger. The difference in spool time between my turbo and rxtreme's could be explained with several differences: divided housing, BB CHRA, 4" exhaust vs. 3", tunned length manifold (I can't remember what he runs), and SP motor. I would guess it's the combination of all that, rather than one component that results in faster spool.
-Chris
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
The Shaolin
Sep 14, 2015 07:50 PM
ashleymiche
Aug 14, 2015 12:59 PM
