T78 with 850's all the way around
Old Nov 29, 2001 | 06:32 PM
R-magic's Avatar
Lightbulb T78 with 850's all the way around
Going with a T78 single turbo this winter break. I need your opinion on 850 for primaries and 850 secondaries. What does everyone think of this setup?
Old Nov 29, 2001 | 07:18 PM
Bacon's Avatar
IRS 4 Life
your gonna need more fuel
even with 1300s secondaries and 850 primaries you might be pushin your luck, depending on how much boost you plan to run
but for the price of having your secondaries enlarged 140 a pop,
you can get the 2krd rail, 220$ and bosh 1600's are 90 bux a piece...
youll deff have enough fuel then
Old Nov 29, 2001 | 11:20 PM
waynespeed's Avatar
Exclamation T78 will swallow all that fuel
T78 will swallow all that fuel. Add two more 850cc injectors for good luck or use 1600cc injectors in the secondaries. This will give you enough fuel to satify that Greedy T78.
Old Nov 29, 2001 | 11:40 PM
vosko's Avatar
Just Call Me Terminator!
i'm gonna run 550's and 1600's and i might need even more fuel but that is why i have the two extra holders in my greddy elbow
Old Nov 30, 2001 | 10:55 AM
13BAce's Avatar
On a long vacation
Why don't you just use the 850's as your primaries?
Old Nov 30, 2001 | 10:58 AM
13BAce's Avatar
On a long vacation
Re: T78 with 850's all the way around
If you decide on 1600's check out http://www.precisionte.com/buicks/injchips.htm They are the place that sells the 160 lb/hr Bosch injectors for $90.
Old Dec 2, 2001 | 05:28 AM
AJC13B's Avatar
10.32 @ 133
Keep the 550s as primaries and get 2 x 1650s minimum secondary. With 45-50psi static fuel pressure, that should be enough for 25psi boost.
Old Dec 2, 2001 | 05:08 PM
zkeller's Avatar
Bacon,
Where are you getting the rail?
Did you adapt the stock fuel pressure regulator?
Old Dec 3, 2001 | 05:32 AM
maxcooper's Avatar
WWFSMD
I wrote a web-based fuel calculator to help figure out how much HP a particular fuel system setup will support. You can change the BSFC, pressure, injector sizes, etc:
http://www.maxcooper.com/rx7/how-to/...tem/calcs.html
-Max
Old Dec 4, 2001 | 10:07 PM
20B10AE's Avatar
Gone Darkside
what is the largest injector that ca fit i a non-modded 2nd gen primary rail? I'm about to run the wolf 4.0 an will most likely pickup the $90/ 1600cc injectors for the secondary.
How hard will it be to tune if I use 550s in the primary and 1600 in the secondary? How about 850 in the primary?
Thanks. . .
Old Dec 4, 2001 | 10:28 PM
ZoomZoom's Avatar
SEMI-PRO
For those of you plannig on using 850s as primaries beware. Large primaries dont ilde well and foul plugs like mad.
Old Dec 6, 2001 | 05:49 PM
XSPOWER's Avatar
850s can idle perfectly so long as you are using factory 850s. if you use the RC 850's then there might be some missing at idle. In fact, I'm sure there will be. Just use factory secondaries in the primary location and with the proper tuning, the engine will idle like stock.
Old Dec 6, 2001 | 06:37 PM
Jedon's Avatar
Slave2TheFD
Is there a how-to or can you give me any ideas on how to properly mount the 850's as primaries? I have read that using two washers helps. I plan on getting my car tuned by XS since I have a PowerFC. Thanx!
Old Dec 6, 2001 | 07:01 PM
13BAce's Avatar
On a long vacation
Thanks. . .
There are a few answers to your thread in the performance forum.
