1/4 mile
Old Oct 8, 2004 | 09:00 PM
we_stcoast's Avatar
1/4 mile
What dose a stock 90 Rx7 non turb run in the 1/4 mile?
Old Oct 8, 2004 | 09:03 PM
JCurry's Avatar
Shpee
mine isnt stock it has exhaust intake it has a porting job done too, lots of other mods, im 16 and i ran for the first time last week, and ran a 17.3 that sux so bad, i launched at 1k and shifted at about 6k, with the clutch slipping the whole time, or i wasnt doing something right, u should be the the 15s tho if u can drive, not like me, what yall think
Old Oct 8, 2004 | 09:57 PM
Dom_C's Avatar
haha ****, a17.3. not to bag on you bud but damn that's over a second worse than stock, how did you manage that? is your 6port system working and your vdi? and launching at 1k. oh well at least you've gotten out to the track. keep working on it. but for the thread i say you will probaly be in the mid 15's if youcan drive decently.
Old Oct 8, 2004 | 10:18 PM
JCurry's Avatar
Shpee
how do you test 6 port system, i have not cat just rb mufflers at the end, and what is vdi, and like a say i should at least be down in the 15s with the streetport and all the other mods i have, my clutch just sux really bad too...
Old Oct 8, 2004 | 10:28 PM
BuffDaddy915's Avatar
Tha ladies man
dont worry about it man, once you got driving down pat...you'll be all good.
Old Oct 8, 2004 | 10:31 PM
JCurry's Avatar
Shpee
i know i only ran once and i got imbarassed and havent raced again
Old Oct 8, 2004 | 10:32 PM
JCurry's Avatar
Shpee
but how can i text the vdi what ever that is and my 6 port system, since i have noting but mufflers maybe i dont have any back pressure, but i dought it since i felt a low end hp gain after the exhaust change, help me out
Old Oct 9, 2004 | 12:01 AM
koukifc3s's Avatar
Clogged cat
stock FC? low 16s
Old Oct 9, 2004 | 12:16 AM
uRizen's Avatar
XBL** Ownicus
I need to take my FC to the track and try it out. There's two strips about an hour away from here and I've always wanted to give it a go. Do you have any tips for a first-timer from afirst time? How much does it cost?
If any of you veterans can provide some good launch tips, that'd be cool.
Personally, during spirited driving, I usually drop at ~3000-3500 rpm, and shift at the buzzer. It seems to work pretty well, and I don't get much spin at all, usually just a small squeel and she takes right off.
Old Oct 9, 2004 | 06:33 AM
bingoboy's Avatar
Lava Surfer
15.8@88 here with rb header/presilencer, borla exhaust, msd6a, safc (half-*** tuned), apex'i intake, slipping clutch, rear agx's on soft and fronts on stiff on stock springs, and pos tires.
15.7@89 buddy's fc with rb header, straight pipe, trust exhaust, pineapple sleeves, portmatched intake manifold, msd6a, safc (also half-*** tuned), k&n cone filter, homemade cold air box, rear agx's on soft and fronts on stiff with rb springs.
15.6@90 'nother buddy's fc with rb header/presilencer, n1 duals, pineapple sleeves, safc (dyno tuned), kumho ecsta mx's, apex'i intake, rear agx's on soft and fronts on stiff with eibach pro springs, and gtus lsd 4.3 rear.
none of us ever took them to the track stock...so i dunno how they'd do in stock form, but this will give you some idea of times with bolt-ons.
Old Oct 9, 2004 | 11:34 AM
koukifc3s's Avatar
Clogged cat
ayye, I really hope I can hit better times when I go to the strip
Old Oct 9, 2004 | 12:53 PM
snub disphenoid's Avatar
I've never run my NA at the track, but my friend consistently ran 15.5@91mph and I consistently beat him by two cars by the top of third gear, so I'd guess I could probably run around 15.2, maybe trapping 93mph.
Old Oct 14, 2004 | 04:38 PM
flamin-roids's Avatar
Lets rock.
Ok I ran 18 flat in my '89 GXL. Here's why. 4700ft above sea level. 5th and 6th ports not opening. Running way too rich and didn't get to launch the car. Reason being the light malfunctioned and started while I was backing up because it wasn't reading me. Without launching the car I pulled a 1.92 60ft somehow. Also the tires I had spun way to much for a good 7k drop. And I have a really light flywheel. So I didn't know how to drop it right. Since then all the problems have been fixed and I'm running new exhaust. Replaced the old all season tires with some fat toyo's. So its reason enough to pull low 16's at this elevation which is very respectable.
Tylerx7fb
39
May 27, 2019 12:45 PM
Turblown
Time Slips and Dyno
11
Nov 20, 2015 07:20 PM
LMBTG
Aug 15, 2015 01:43 PM
