Vacuum caps
Old Oct 6, 2004 | 11:33 AM
allenhah's Avatar
Dirty
Vacuum caps
Hey guys...I'm trying to get things together for my single turbo install, and I just wanted to know where you guys get the caps for the vacuum hose nipples. What size, how many, and where's a good place to find them? Also where can I find the block-off plate for the rear oil passage? I *think* that's about all I need, but if you guys can think of anything else, that would be great!
Thanks!
Old Oct 6, 2004 | 04:36 PM
Infini IV's Avatar
Microtech Tuning!
You can get the caps at Autozone or Pep Boys or Kragen.
Old Oct 6, 2004 | 04:57 PM
allenhah's Avatar
Dirty
That's what I was thinking too, and I went to the local Kragen, but they didn't carry anything of the sort for some reason...maybe it's just that one shop...
Old Oct 6, 2004 | 07:29 PM
rotarypower101's Avatar
sdrawkcab
just dont get the shinny polyurethane caps. They expand way to much when exposed to heat and can pop off. The rubber ones seem to be a better solution.
They usually have bins full of them or little variety packs.
Old Oct 8, 2004 | 05:26 PM
jg1bad10th's Avatar
parts for sale
I just got mine from Autozone.less than 7.00 for all of them.
Old Oct 8, 2004 | 07:13 PM
BLUE TII's Avatar
Rotary Motoring
My experience is the rubber ones degrade very fast in the engine bay heat.
The vinyl ones are more heat resistant by a wide margin, but they don't have quite the elasticity the rubber ones do so I use superglue and zip ties with them.
Silicone rubber caps are available from anywhere that does or sells powdercoating supplies (Eastwood?) as that is what powdercoaters use to cover threaded/machined studs on powdercoated parts as it can resist the heat of the curing lamps. This non-reinforced silicone is weak against tearing and prone to oil degredation, but it had good elasticity and high heat capabilities.
I have also taken small sections of stronger high quality silicone hose and filled one end w/ silicone sealant to make caps. A quick trim on the ends w/ a razor and it looks and works very well.
Old Oct 9, 2004 | 04:22 AM
Infini IV's Avatar
Microtech Tuning!
I've done something similar, though I stuck one end of the hose on the nipple, stuck a screw in the other end. This seemed to work better than those caps.
Old Oct 9, 2004 | 01:05 PM
www.hosetechniques.com
Old Dec 3, 2008 | 07:27 PM
AcidAngel7477's Avatar
We're All Fkd..
i wish someone would make some nice silicon vac cap's cause i use the cheap *** auto zone/ pep boy's vac cap's and i have to change them every so often cause they crack and cause vac leaks for me..weird too cause i was going to create a thread about this and i came across this one..anyone know if they make these silicon vac caps..??
:AA:
Old Dec 3, 2008 | 07:38 PM
C. Ludwig's Avatar
www.lms-efi.com
McMaster-Carr to the rescue again. I've used their silicone caps for years. They won't dry out, crack, and shrink like standard rubber caps.
http://www.mcmaster.com/ctlg/DisplCt...54344087987953
Old Dec 3, 2008 | 07:42 PM
afterburn27's Avatar
Lets Go Hokies!
Definitely don't use standard rubber caps, they won't last very long at all. I have never had any luck finding a good source for high quality silicone vacuum caps.
I have done the same thing and it seems to work OK. What I usually do it go to the hardware store and find a shouldered bolt that is a nice tight fit in the silicone hose I am using. I then cut off the threaded porting and insert the bolt into the hose. Add a zip tie and you have a bullet-proof vacuum cap. Yeah, it doesn't look super professional, but hey it works great. I also do the same thing for capping off the AST coolant connections.
Old Dec 3, 2008 | 09:09 PM
We're All Fkd..
witch one's do it get..??i forgot what size they are.
:AA:
1/8" 1" 50 6448K72 $5.97
9/64" 1" 50 6448K73 6.30
5/32" 1" 50 6448K74 6.41
11/64" 1" 50 6448K75 7.17
3/16" 1" 50 6448K76 8.68
1/4" 1" 50 6448K77 9.66
5/16" 1" 50 6448K78 9.86
3/8" 1" 25 6448K79 6.41
7/16" 1" 25 6448K81 8.25
1/2" 1 1/2" 25 6448K82 8.53
9/16" 1 1/2" 25 6448K83 9.09
3/4" 1 1/2" 10 6448K84 5.08
7/8" 1 1/2" 10 6448K85 5.55
1" 1 1/2" 10 6448K86 7.24
Old Dec 3, 2008 | 09:13 PM
We're All Fkd..
im going to guess 5/32 or 11/64...
:AA:
Old Dec 3, 2008 | 10:53 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
Good find on the silicone caps Ludwig! I freakin' love Mcmaster.com ... I usually find myself browsing that site for hours looking at all the little odd parts for custom projects.
Old Dec 4, 2008 | 07:50 PM
ryan1's Avatar
I brazed all my unused nipples closed, got tired of vac. caps coming off.
Old Dec 14, 2008 | 09:50 PM
We're All Fkd..
soooo...what size do i get..?
:AA:
Old Dec 14, 2008 | 11:10 PM
Busted7's Avatar
Will work for horsepower
Im with you there no leaks and no caps in two years. I even brazed the water line closed and there 3/8 dia.
I put rubber caps on just to keep me from cutting my hands!
