Alarms, got suggestions?
Old Oct 2, 2004 | 11:00 PM
apex_sideway's Avatar
FD dream is dead
I'm in the market for a alarm; suggestions? -Clayton
Old Oct 3, 2004 | 08:17 AM
David88vert's Avatar
r71's daddy
Anything DEI (Viper, Sidewinder, Python, etc.) or Omega (get it from Kickyride.com - that's puaka here on the forum).
Old Oct 3, 2004 | 10:43 AM
SpiritRex7's Avatar
Antracite Supra
lynx 2000, its $225, 2 mile radius LCD pager w/and fd on it BTW, remote start, proximity sensor, open entry alarm sensor.
Scott
Old Oct 3, 2004 | 10:56 AM
RecKleSs's Avatar
Adrenaline
This is probably one of the best unit out there http://www.directed.com/security/viper/gps.asp# Also, check out the video clip on, "Watch Viper GPS Tracking Systems on CNN Headline News!"
Old Oct 3, 2004 | 12:20 PM
rotoboy661's Avatar
audiovox prestige 996c
everything u need
Old Oct 3, 2004 | 07:02 PM
FD dream is dead
Scott
Is this the alarm off AsianWolf's website? Do you have this system yourself? How does it work for you?
Old Oct 5, 2004 | 02:45 PM
FD dream is dead
Bump
Old Oct 5, 2004 | 02:50 PM
Foz'sRX-7's Avatar
If it's for your FD...............forget about keyless entry..........almost all of the systems will break the cable that unlocks the passenger door, and it's not cheap to replace ($250).
I've stuck with the stock alarm because of that.
If there's a new one out there that will work...........let me know!
Old Oct 5, 2004 | 07:22 PM
r71's daddy
Hmm, I've installed a lot of alarms on FD's with keyless entry over many years - and I've never seen even one break. Use quality parts and have a competent installer and you shouldn't have problems.
Old Oct 5, 2004 | 08:02 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I've had keyless entry on my fd 2 years now with no probs at all.
Old Oct 5, 2004 | 08:06 PM
FD dream is dead
Can anyone tell me what alarms THEY have on their car? Impressions?
Old Oct 5, 2004 | 08:44 PM
rotoboy661's Avatar
same here
sup gene
Old Oct 5, 2004 | 09:11 PM
teamafx's Avatar
crimestopper cs-2016 with paging unit, pages me on the remote up to 1/2 mile away if there are any problems, has a remote start for a manual, and a built in turbo timer. I love it, and Im an authorized dealer too, so it works well
Old Oct 5, 2004 | 09:43 PM
7-sins's Avatar
thats not paint....
dont buy one off ebay, I got one for the beater and it wasn't worth all the **** I went though
Old Oct 6, 2004 | 09:01 AM
Iggy76's Avatar
Here goes: When you are buying (or looking at buying) an alarm, you have to decide what you want the alarm to do before you go looking for a specific brand. All of the brands mentioned above are probibly reputable and work terrifically.
What are you trying to protect? Are you worried about someone stealing your car? Are you worried about someone taking the contents of your car? or are you worried about someone vandelizing (sp?) your car? You should decide the level of security you want before anything else. It is really, really hard to protect against vandelism; easier to protect the contents and easier still to protect the actual car. Just remember... if someone wants it, they are going to take it... alarm or no!
You should also decide the convienence features you want to have (or might want to have in the future). For example: trunk pop, parking light flash, horn honk, window roll-up/-down, sunroof roll-up/-down, remote start, remote controlled things (neon, radio, robotics, hydraulics etc). Most of these require extra outputs to control, so choose an alarm that will suit your needs.
HAVE THE ALARM PROFESSIONALLY INSTALLED! Choose a reputable shop that you trust to install the alarm properly. This will prevent any problems from occuring due to the installation. Most alarms warrenty's are only valid if an authorized dealer installs them, and shops will warrenty their work so if anything goes wrong you will be covered.
That said I have a viper 690xv in my car (240sx) and I have had no problems that were not self-inflicted.
Old Oct 6, 2004 | 10:22 AM
FD dream is dead
I'm worried about vandalizing and someone actually stealing the car. I'm thinking about going with a viper with glass sensors. Thanks everyone for your input . . . good essay Iggy76
Old Oct 7, 2004 | 01:34 AM
InsaneGideon's Avatar
Still on 1st engine
Just a misc. FYI: the prestige APS996 has a "higher range" version out called the APS996A.
As for the keyless entry snapping cables. I believe that was the problem for people who clamped the actuator arm's linkage to the cable's crimped-on end. It's tempting to do because it's easy.
If you hook the linkage up to the inside lock lever's plastic arm, it helps distribute the actuator's force... at least that's the plausible semi-explaination. It worked fine for me and for many others. YMMV, but if it breaks on you, you'd be the first I've heard of. Search for a post by NewbernD. I think he's the originator of the idea. There's a pic posted of a red FD door that will describe the whole thing.
93FD510
Oct 1, 2015 02:00 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
lnlreaper
Sep 27, 2015 09:59 AM
ls1swap
15
Sep 8, 2015 05:30 PM
