AR exhaust housing
Old Sep 27, 2004 | 04:34 PM
yonner's Avatar
AR exhaust housing
what problems would you incounter with running a tight AR exhaust housing like .45
Old Sep 27, 2004 | 04:59 PM
Sonny's Avatar
R1derful
If the a/r is numerically lower, it will shift the powerband down and the peak power will be lower and occur at a lower rpm. Benefit is faster spool.
If it is numerically higher, reverse the above.
Sonny
Old Sep 27, 2004 | 05:24 PM
yonner's Avatar
so with a low ar i could get around 350 hp with a good fast spool?
Old Sep 27, 2004 | 05:32 PM
Kevin T. Wyum's Avatar
None
Depends on the compressor size and the rest of the car and what boost you'll run. The best way to think of it is that your efficiency island will shift toward lower RPM overall, Sonny had a good explanation.
Kevin T. Wyum
Old Sep 27, 2004 | 05:53 PM
Sonny's Avatar
R1derful
The Garrett T3/T04E hybrid turbo is very popular for this reason. You couple the fast spool of the T3 turbine side with the power ability of the T04E/S/R compressor family to have a pretty versatile setup.
Here's an example:
That's a 1.7 liter Honda engine running about 25 psi of boost through a Garrett T3/T04S (T3/60-1) turbo.
Specs:
Garrett T3 "stage 5" turbine wheel
.82 a/r T3 exhaust housing
Garrett T04S (60-1) compressor wheel
Garrett T04S (.70 a/r) compressor housing
This setup is pretty extreme and obviously not a real good choice on the street. It is very laggy. The whole powerband could be shifted down by 1000+ RPM by switching to the .63 a/r exhaust housing and/or the smaller stage 3 turbine wheel. However, you would lose power on top, so it's a trade off.
If I ever get the money and can legally do it (ie, leave California), I'm gonna try Full Race's T3/T67 on my car. I have no doubt that the rotary could spin this turbine up early and then take advantage of the huge compressor attached to it.
Sonny
Old Sep 27, 2004 | 05:59 PM
yonner's Avatar
i have a TO4R compressor .70 a/r 66.5mm inducer - flow: 75 lbs/min 960cfm - 360* thrust bearing standard
and a blitz T04E 57T
i want as litle lag as posible and a good 400 fwhp at lest 350 to the rear wheals
Old Sep 27, 2004 | 06:09 PM
Sonny's Avatar
R1derful
The above only says what you have in terms of a compressor.
The T04R compressor is also commonly known is the "T67". You can make A LOT of power with that compressor. The Blitz is just a T04E 57 trim compressor. The 57 trim TO4E will flow about 50 lb/min. It's a much smaller compressor than the T67.
What you need to find out is the trim of the turbine wheel and the a/r of the turbine housing.
Sonny
Old Sep 27, 2004 | 06:49 PM
yonner's Avatar
i am thinking about buying this
COMPRESSOR SPECS:
flow: 50 lbs/min 640cfm
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
standard with 270 degree thrust bearing
what u think
Old Sep 27, 2004 | 06:57 PM
Sonny's Avatar
R1derful
I think that turbine housing will be way too small for what you're trying to do. You'll have to ask some others here for advice, but I would imagine that the rotary can spool the turbo pretty well (ie, with a liveable amount of lag) with a .82 a/r housing.
Sonny
Old Sep 28, 2004 | 06:12 AM
yonner's Avatar
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
oil lubricated centersection.
so would this one be any good???
Old Sep 28, 2004 | 06:19 AM
yonner's Avatar
ok i have the chance to buy an hks t04e full kit the trim is 57t the a/r is 0.84 with a racing waste gate. will that spool at least 3000 rpm?
FD7KiD
15
Feb 26, 2021 10:12 PM
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
jjandros
Aug 28, 2015 08:01 PM
FD7KiD
Aug 17, 2015 11:50 PM
