T78 in an FC?
Old Sep 20, 2004 | 07:13 PM
Half Jap Boost Junky's Avatar
240RWHP 270TRQ @ 0.9Bar
Question T78 in an FC?
I just found a GReddy T78 turbo for a pretty good price and I just wanted to know how much, if any custome work would be required to install it into my S5 FC. I already have a 25G turbo, but this deal is almost too good to resist. I just want to make sure that it won't be too difficult to install when the time comes. Will it just drop in with the proper manifold? Or will I have to "make" space for it.
Also, once I get it into the car, will I even be able to spool it properly once the proper supporting upgrades have been made?
Thanks.
Old Sep 20, 2004 | 07:28 PM
Black97VR4's Avatar
FEARED
I know you CAN do it, just not how. Forgive me for being an FD guy but with my limited knowledge of FCs I do believe it will work just fine assuming you can get a manifold and downpipe to match.
Old Sep 20, 2004 | 10:04 PM
1revn3rdgen's Avatar
I pretty sure evrything will fit good you just have to custom make a downpipe.
Old Sep 21, 2004 | 04:25 AM
Do any of you guys know if the GReddy T78 is a dual ball bearing turbo?
I would also like some input from people that are using this turbo, what kind of boost lag if any are you getting when you run the 1/4 mile. I'm building this car to drag at the track next year. I'd like to be in the 11s if possible.
Old Sep 21, 2004 | 04:42 AM
Infini IV's Avatar
Microtech Tuning!
The T78 is a standard bearing turbo. Although if you search, you should find answers... I believe most people make full boost right around 4500rpm.
Old Sep 21, 2004 | 04:43 AM
Jon Goodwin's Avatar
Fits straight in, easier than the stock setup. Oil lines are probably the most difficult...which is not much. About 5psi at about 3300, holds until the secondaries open at about 3600. 10psi at about 4200, and carries on building.
John
88 GT-R
Old Sep 21, 2004 | 04:44 AM
Fits straight in, easier than the stock setup. Oil lines are probably the most difficult...which is not much. About 5psi at about 3300, holds until the secondaries open at about 3600. 10psi at about 4200, and carries on building. Obviosly individual engine builds and setups apply.
John
88 GT-R
Old Sep 21, 2004 | 11:47 AM
95R2-89TII Ground Zero's Avatar
Banned
John
88 GT-R
What mods are needed for the oil lines? Length should be a small issue.
Old Sep 21, 2004 | 11:56 AM
No mods needed, just an effective setup so as to prevent leaks. I assume that anyone fitting the Trust/Greddy T78 will be using the Trust manifold and wastegate.
John
88 GT-R
Old Sep 21, 2004 | 12:21 PM
eViLRotor's Avatar
Brother of the Rotary
Streetpower has a T-78 FC. Talk to him, you can probably check out his car.
Snoopy FD
Dec 8, 2015 01:45 PM
Snoopy FD
Aug 19, 2015 03:40 AM
zayrx7
Jun 21, 2002 01:37 PM
