advantages of FD intake manifold vs. s5?
Old Sep 19, 2004 | 01:22 AM
d0 Luck's Avatar
raysspl.com
i'll be doing a t2 swap for my FB soon, but i need to know which intake manifold is actually better. or are they pretty much the same? i figured i'd ask here in the FD section since you guys know your FD stuff
thanks in advance fellas
Old Sep 19, 2004 | 02:23 AM
d0 Luck's Avatar
raysspl.com
sooo.. any good takers?
Old Sep 19, 2004 | 01:42 PM
d0 Luck's Avatar
raysspl.com
no one knows???
Old Sep 20, 2004 | 12:43 AM
d0 Luck's Avatar
raysspl.com
bump
Old Sep 20, 2004 | 09:39 AM
bond007's Avatar
Post quality not quantity
I don't recall the exact physical data behind his decision, but a friend who is building up his S5 T-II is using a FD manifold. For your reference, most of his car is going to be custom fabbed, but I think he came to the conclusion that it would flow better for his purposes (street port, upgraded turbo, FMIC) and I don't recall it being an "exact" fit (as in, bolt-on). Perhaps if you search some more you can get the reasoning behind this "canned" answer.
Old Sep 20, 2004 | 12:40 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
the FD manifold flows more air, as it the runners are bigger, also it lets you use the FD throttle body, which is bigger too. Just so you know, FD manifolds do not bolt up to the S4 or S5 motors. If you want, I have an adaptor plate that allows you to use an S5 LIM, with FD UIM and throttle body. PM me if you are interested...
Neil
Old Sep 20, 2004 | 02:51 PM
d0 Luck's Avatar
raysspl.com
but are the s5 and FD lower IM different or same?
yeah, ill definitely think about it 1fastrx7
Old Sep 20, 2004 | 04:15 PM
95R2-89TII Ground Zero's Avatar
Banned
No, the LIM for the S5 and FD are not the same, otherwise you wouldn't need the adapter to make them bolt up.
Old Sep 20, 2004 | 11:08 PM
88IntegraLS's Avatar
Displacement > Boost
if the s5 tii mani is like the s4 one, it has straight runners coming from a plenum fed by a throttle body while the fd one has curved runners adjacent to a plenum . . curved runners support the "tournament effect" in rotary induction, where a closing port causes a mild positive pressure wave that intersects the incoming air at the top of the u shaped runner, and supports the incoming wave of the other side of the u to the opposite port. Check out the N/a S3, S4, S5, and RX8 intake manis to see this feature. S5 mani had a variable distance U "variable dynic induction or VDI" and RX8 probably features same technology.
Old Sep 21, 2004 | 01:50 AM
rotarygod's Avatar
Rotors still spinning
Actually the FD manifold runners are smaller than the T-II manifold runners. This is interesting since the FD throttlebody is larger.
Old Sep 21, 2004 | 11:11 AM
RacerXtreme7's Avatar
NASA geek
ACTUALLY....... the 3rd gen runners are both bigger yet smaller..LOL.
The 3rd gen intake has larger secondaries and smaller primaries when compaired to a series 5 intake. Its has a ever so slightly longer runnner length, I think flows better not only because the larger throttle body bore, but it has less bends and the ones that are there are more gradual. the TII series 5 lower intake is a better design having straighter runners and having the secondaries injectors farther from the intake port, but the 3rd gen intake enters the motor at an angle is better then the abrupt turn for the perpendicular ports of the series 4,5.
BOTH series 4, 5 and 6 (n/a, and turbo) use the "tournament effect" intake. The series 4, 5 do not have a plenium feeding the runners, its just like the 3rd gen intake but wrapped around 90 degrees.
~Mike.................
Old Sep 21, 2004 | 04:50 PM
d0 Luck's Avatar
raysspl.com
i mean the air velocity..
Old Sep 24, 2004 | 02:18 PM
Triangle Power's Avatar
Big Wankel
so... for someone with a street ported S5 TII motor looking for more, the best setup would be the S5 LIM mated to the FD UIM via adapter plate along with the FD throttle body? I already have the Greddy FMIC kit installed in my S5 TII. WIll the FD throttle body line up the same so I don't have to modify the piping? Thanks.
Old Sep 25, 2004 | 09:07 AM
jspecracer7's Avatar
1JZ powered
You'll have to modify piping.
Old Sep 25, 2004 | 10:42 AM
hIGGI's Avatar
My setup : S5 LIM, adapter, FD UIM + TB, adapter, newer Greddy FMIC kit :
Old Oct 2, 2004 | 10:41 PM
d0 Luck's Avatar
raysspl.com
where can i purchase the adapter plate to bolt on the Fd's upper intake mani to the s5 lower intake mani??
thanks fellas!
Old Oct 3, 2004 | 06:14 PM
toothpicsk8's Avatar
where can i get a light kit liek that, it looks sick!
Old Oct 3, 2004 | 09:17 PM
Merovingeon
Veteran: Air Force
the kit looks like the RE Amemiya FC2000 kit. either the real thing or a knock off. either way, its a nice upgrade, imho
neil
Old Oct 3, 2004 | 11:03 PM
bdls's Avatar
jt import sell the adapter kit its near the bottom of the page http://www.jt-imports.com/FEED_FC_Parts_List.htm
Old Oct 5, 2004 | 10:38 PM
d0 Luck's Avatar
raysspl.com
whoa... that's pretty expensive. i'm sure there's other alternatives though
Old Oct 6, 2004 | 02:54 AM
hIGGI's Avatar
sure, do it yourself
DerpyToast
14
Nov 23, 2024 05:19 PM
rgordon1979
40
Mar 15, 2022 12:04 PM
armans
Sep 6, 2015 09:02 PM
