True dual system questions
Old Sep 12, 2004 | 09:40 PM
classicauto's Avatar
Crash Auto?Fix Auto.
just a couple quick questions on real dual setups:
1-should i use a H or X pipe section?
2-will putting the factory 02 sensor in one pipe in the header make readings good enough for the 02 sensor?
3- what dia. of pipe is used for the header section (i think 1 7/8")
thanks in advance
Old Sep 12, 2004 | 09:48 PM
marlaman's Avatar
Need an E6x
1. i'd do neither if you want true dual. you'd have to know how to tune exhausts. but if you chose either of the 2, i'd go with X.
2.yes
3.On my setup it's 2.5in all the way back from the engine. header included.
Matt
Old Sep 12, 2004 | 09:49 PM
Beny's Avatar
i believe that the O2 sensor would have to go in the collector part of the pipe, yes?
Old Sep 12, 2004 | 09:57 PM
thanks marlaman, i like sound of 2.5" the bigger the better, especially when i consider my factory type setup uses a single 2.5" section from the manifold to the Y
Old Sep 12, 2004 | 09:58 PM
sudseh's Avatar
Attack Gas Station!!!!
doesn't HAVE to i don't think... your ecu should be able to compute the a/f via one rotor, and provided your rotors are running equally, you will have no problems.
Old Sep 13, 2004 | 12:56 AM
RXciting's Avatar
GrapefruitRacing?
thanks in advance
You can't have a true dual H or X pipe.. or at least that's how it is to my knowledge
True dual means the 2 banks on a V configuration engine's exhaust (or in this case 2 rotors) never collect or meet
I think the one i have from mazdatrix.com is a twin 2-2.5" front to back
Frank
Old Sep 13, 2004 | 01:03 AM
I like the mazdatrix setup. But I'm also intrigued by the RB.
But to answer the questions.
1. No X or H, either Y or true seperate duals from header back.
2. Yes
3. 2.5" Bigger the better.
But I have a question of my own. Is there such a thing as too big on a 7? In my opinion the rotary responds better and better the bigger the piping.
Rabbit
Old Sep 13, 2004 | 01:20 AM
RXciting's Avatar
GrapefruitRacing?
Rabbit
Bigger the better on an N/A is not true
Rabbit
a tuned exhaust is made so that at a certain RPM the exhaust gases flowing through it maintain momentum between exhaust pulses thus creating a scavanging effect when the next exhaust pulse comes around.
if the exhaust is too restricive then that momentum/scavenging effect is reached at too low RPM's or not reached at all and cause backpressure at higher RPM's
If the exhaust is too large then the exhaust gases will not be able to get sufficient momentum and also cause another problem when the next pulse comes out since it's gonna hit air that's just stanting still and have to move that out of it's way
also exhaust and intake have to almost be tuned together.. but i guess that's another story.. BUT!, too large of an exhaust will not be beneficial to a stock intake manifold
Old Sep 13, 2004 | 01:56 AM
Will 3.15" true duals be fine on a port+polished intake manifold?
Old Sep 13, 2004 | 02:34 AM
xfeastonarsex's Avatar
fire from MY tailpipe!
Matt
exactly, it isnt a "true" dual unless they are seperated the whole way back.
ya you can have too big of pipes on any car...
Old Sep 13, 2004 | 12:45 PM
RXciting's Avatar
GrapefruitRacing?
i'm thinking anything over 2.5 dual for an N/A is just too damn big
maybe if you had a P-Port but i still think a 2.5 dual would be suffiecient
Frank
Old Sep 13, 2004 | 01:12 PM
Icemark's Avatar
No, neither... will drop torque if you do
yes
thanks in advance
2" is perfect... do not go any larger than 2.5" or you will loose considerable exhaust volocity.
immanuel__7
89
Sep 5, 2015 10:23 AM
c0rpse
Aug 25, 2015 11:50 PM
