Keyless entry/power locks
Old Sep 12, 2004 | 04:05 PM
barcode's Avatar
Interested in adding keyless entry and or power locks to my '87 Turbo. I bought the autoloc kit that came with motors/actuators for the locks but that didn't work, so I was curious what the rest of you have done to get a system working and if so, which you went with and all that. I searched around quite a bit and nobody seems to have a really solid answer.
Thanks,
Sam
Old Sep 12, 2004 | 04:28 PM
RexRyder's Avatar
what do you mean it didnt work? maybe it was faulty? return and get another one.
Old Sep 12, 2004 | 07:19 PM
Icemark's Avatar
you need to add a door lock actuator to the drivers door to add keyless entry (and to the passengers door if you don't have factory power locks.
it is very straight forward for even the most basic installer
Old Sep 12, 2004 | 08:04 PM
barcode's Avatar
The actuators wouldn't push the locks, I had it in per the instructions as best as I could tell, and I had a friend who owns a shop look at it and he couldn't figure out why it wouldn't go, so I was interested in possibly swapping in the factory power locks and then using the keyless set up that runs on the PDL wires instead of coming with it's own actuators. My question I guess is really more of, how hard is it to put the stock PDL in on a car that doesn't have it, sorry it wasn't stated too clearly.
Old Sep 12, 2004 | 10:16 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Thumbs up Been there, done that
Your very best bet is to get a passenger door actuator from a wrecking yard rx7. Don't forget to get the plastic snap from the door locking mechanism that the actuator rod slides into, the mounting bolts (2 of them, 10 mm's as I recall), and cut the twin wire (red and green as I recall) so that you capture both the male and female plug (will make the wiring easier if you do)
Reverse the mounting of the mounting bracket and bend the top end of the rod the opposite direction. Then just bolt in the drivers door (the holes are already there), slide in the plastic snap on the locking mechanism, slide in the actuator rod, and you physical installation is complete in about as factory like installation as you can do.
Now, the actuator works on a reverse polarity principal. Positive to one wire, negative to the other actuates it. Just about any after market alarm system will have a "pulse" output for this purpose. Connect the red and green wire to the alarm's "pulse" twin wire output according to the directoins, and your done.
What is also fun is to get the window module. With that, when you arm the alarm, it rolls up the windows. Also, (at least with mine), a push of a third button after arming will crack the windows for hot day parking. In addition (fun feature), if you push the third button after dis-arming, the windows roll down.
Have fun.
PS to IceMark. Great finally meeting you at the 7Stock reception.
Old Sep 12, 2004 | 10:25 PM
Cybaster's Avatar
I think I'm addicted
the factory door locks is a follow up system =) so it is not really a TRUE lock system with 2 actuators.... u press the driver's door, it activates the door lock actuator on the passanger side and it locks the passanger door....
so swaping that in u will still need a actuator to lock the driver's door, then it acts the same ways like i described, the driver's actuator will lock the driver's door then it activates the passanger side also....
ask Icemark, he knows everything about follow-up door lock for the FC....
but u should check if the actuators do work? put a 12 volt wire to one and ground the other.... check that... if it works, maybe your 12 volt constants or grounds are not good?
how about the keyless entry module? does it have power to it and a good ground?
if the actuator do not move at all when power is added to it, then the actuators definitely defective.... if they work, then it is your keeyless entry module... either defective or bad connection....
that is my advice, check that....
cuz i think it should work, and alot of forum members have keyless entry done, so as Icemark say, it should be relatively easy.... i think much easier than the factory PDL....
(well, when i investagated my door problem, the Factory one confused me =)
good luck!
Old Sep 13, 2004 | 01:10 PM
Cybaster's Avatar
heh heh, sorry, just a correction... the Factory Power Door Lock system (like my TII) is called the follow me system, not follow up system.... (just a name mix up)
i guess i needed sleep last night =D
Coochas
Oct 3, 2015 04:49 AM
rotor_veux
Sep 28, 2015 09:25 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
