IDEMITSU oil vs. any other oil, ran in 787B
Ok I just got the new issue of RXtuner and saw an add for this oil i was just wondering if anyone is running it in thier 7, and how it comares to other oils on the market?
www.idemitsu-usa.com
https://www.racingbeat.com/FRmazda3.htm
Idemitsu oil and premix
I haven't seen any direct comparisons between Idemitsu full synthetic and other motor oils myself. It has just become more available here in the US, and I'm sure more information will trickle in as engines become torn apart after using it. However, Mazda has worked extensively with Idemitsu in the development of these lubricants and I trust in their knowledge to know what is best for the rotaries. It is a synthetic oil, so oil changes would not have to be as frequent.
You can get it at RotorSports Racing. The number is 704-933-6222 and more information is at http://www.rotorsportsracing.com/per...g/idemitsu.htm. It's pretty much the same information on the Idemitsu site. But you can order it by the quart or by the case.
if you're changing it during normal intervals (3k miles or whatever) I doubt it'll be more beneficial than a good synthetic or good mineral based
if people are using their oil for prolonged periods...prbly better but again, I doubt it would be much better than a good synthetic
As per Ari/Chris, Ken Scheepers used it on his 10 sec all motor peri port drag car with outstanding results.
I plan on ordering up a case of 10w30 for winter use.
Trending Topics
alphawolff
Nov 17, 2015 05:57 PM
NCross
Sep 3, 2015 03:42 PM
