FAN COOLING MOD...30 second job
Old Nov 23, 2001 | 04:04 AM
Apexi's Avatar
I saw a post by Twinturboteddy awhile back saying to pull the A/C fuse as a cheap fan trick? Ie/ when u turn on the AC, the AC won't work, but the fans will go on high?
Anybody try this? Are there any side effects to doing this? Ie/ is the A/C system completely non-functional with the 15A fuse pulled, no gas circulating, nothing on the AC side operating?
Thanks
Old Nov 23, 2001 | 04:30 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I'd like to know also!
Old Nov 23, 2001 | 02:28 PM
GsrSol's Avatar
Z06 powered FD
As long as the compressor doesn't come on, it should be fine.
I'll try this later and let you know.
Old Nov 23, 2001 | 05:17 PM
rx7even's Avatar
Another idea would be to rewire the fuse and run it inside the car within your reach, so you could pull the fuse as you wanted, or pop it back in and use the AC. Or wire up a switch, so on) compressor is on, off) compressor is off. Just a quick 10 second thinking there, dont know if it would actually work yet or not.
Old Nov 23, 2001 | 05:44 PM
pp13bnos's Avatar
Pineapple Racer
find anything out?
Old Nov 23, 2001 | 07:31 PM
atihun's Avatar
Two minute fix:
Take the kick panel off of the passanger side.
Attach a wire to the lose wire from the fan relay, attach that wire to a on/off switch.
Attach another wire to the other lead on the switch and ground it.
Voila.
Turn on switch for two minutes and both fans come on medium.
If you leave the switch on it will leave the fans running for 10 minutes on medium after you shut the car off.
Sometimes, if the temp is very hot, even if you turn off the fan switch after turning off the engine, the fans will run for 10 minutes on low.
Here in Southern California, I always drive with the fans on, and it keeps my temps around 86 normal cruising, and around 93 when driving hard.
Old Nov 24, 2001 | 02:28 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
I have done this A/C trick. I have had mine pulled for the last 2 months or so. It works great at keeping the car cool but you won't be if you are used to running with the A/C. With the replay pulled the A/C becomes non-functional. The computer will think that the A/C is on, thus kicking on the fans, but as far as I can tell nothing under the hood A/C wise comes on.
Old Nov 24, 2001 | 02:54 AM
Apexi's Avatar
wuts the difference between pulling the AC relay vs pulling the AC fuse? Same result?
Just want to make sure that the compressor isn't turning on.
Old Nov 24, 2001 | 03:15 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
I just pulled the A/C relay. I didn't touch the fuse. And as far as I can tell the compressor does not turn on.
Old Mar 9, 2002 | 08:32 AM
rxrotary2_7's Avatar
Originally posted by Rotary427
why is everyone talking about the dangling black wire fan switch mod when the guy is asking about the pulling A/C relay mod?
Adrian
because they are giving him other ideas, and other options of doing the same thing. would you like all posts in this thread that do not have to do with a relay deleted? would that comfort you? :rolloeyes:
Old Mar 9, 2002 | 06:42 PM
I gotta ?
What good is this mod while the car is turned off and the water is not circulating?
Old Mar 9, 2002 | 06:56 PM
0piston's Avatar
A couple of other things you can do is change out the coolant thermoswitch for a Miata one. it is a straight replacement and this turns your fans on earlier than the stock one. There is also the air-conditoning POS that is blocking air to your radiator, unloosen the top mounts and bend it downwards. This allows a little more fresh air to pass through the rad. If you had some coffee you could be creative and modify some aluminum sheets to force the air through.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
Blastfastrotary
Sep 11, 2015 12:26 AM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
